What type of balun can i use for stm32wle5 433mhz?
Options
2023-04-10 9:38 AM
I have to create a pcb for stm32wle5 for Lora 433 mhz ( 2 layers, hp) But in references I didn't find any balun for this frequency. Only for 490+ mhz.
What balun can I use for 2 layer 433 mhz?
With regards
Labels:
LoRa
STM32WL series
1 REPLY 1
Options
2023-07-26 4:49 AM
Hi Yevhen,
I also have the same problem.
I am designing a PCB with STM32WL54CC to work at 433MHz and i am not sure if the BALFLB-WL-08D3 can be a good chois.
Do you have tested a balun for your circuit or you have set SMD components ?
if yes what do you recommend ?
Thank you,
Sincerely.
