SUBGHZ _ issus in switching between Tx & Rx mode
‎2022-03-29 5:08 AM
I develop an application with SUBGHZ in transmitting and receiving mode.
I have initialized the hardware and configured the SUBGHZ peripheral.
I use the switch (PC3, PC4, PC5) to change between Tx and Rx mode, but i steel receiving data from RF even I am in Tx mode, and I cannot send data!
- It is normal to receive data after switching to Tx
- And why I cannot transmit data !
Any body have suggestions to resolve this problem ?
Thank you,
Sincerely.
- Labels:
LoRa
STM32WL series
‎2022-04-05 6:32 AM
On which code are you starting ? Are you sure to have correctly setup Tx mode and modified the code to switch correctly from one mode to an other ?
‎2022-04-08 7:28 AM
Hi LAUDO,
The problem was in my own application, i was write it without SUBGHZ_Phy drivers. now after add SUBGHZ_Phy library the problem was resolved. but i have not find where was the problem.
