2024-12-19 11:40 PM - last edited on 2024-12-20 3:54 AM by Andrew Neil
We have developed wireless temperature sensor using STM32WL5MOCH6S module , it is fully battery operated device and Battery is connected directly to supply pin of the module, in this we would want to the read battery voltage , is there any register or command available for reading supply pin to read the battery voltage or any other method to read the battery voltage?
Kindly help us in this matter.
2024-12-20 3:56 AM
Have you checked the Datasheet and the Reference Manual - they would show you what options the ADC has for its input/source to measure ...
