STM32WL RF Layout – Routing Signals on 3rd Layer Near RF Section & Stack-up Changes
Eranga
Hi everyone,
I’m working on a 4-layer PCB design using the STM32WL (based on the Nucleo WL55JC reference design).
For the RF section, I followed the same layout approach as the Nucleo board, including the layer stack-up and RF trace widths.
The only difference in my design is that I have some GPIO signals routed close to the RF section. These signals are routed on the 3rd layer, while I am still maintaining solid ground planes on the 2nd and 3rd layers underneath the RF section.
I would like to clarify:
  • Is it acceptable to route non-RF signals on the 3rd layer near the RF section if solid ground planes are maintained?
  • Are there any risks (e.g., noise coupling or RF performance degradation) with this approach?
Additionally, if I modify the layer stack-up:
  • What parameters need to be adjusted (e.g., RF trace width, impedance matching, ground reference)?
  • Are there any recommended guidelines for maintaining RF performance when changing the stack-up?
Any guidance or best practices would be greatly appreciated.
Thanks in advance!
Imen.D
Hello @Eranga
I recommend you these guidelines for STM32 RF guideline courses and optimizing RF:
Imen
