2022-06-07 12:55 AM
I'd like to know if it's possible to use RTC with a BCD Calendar mode with the end node example. Indeed, I've tried to, but it seems that the timer server doesn't work when i'm not using the binary mode.
Thanks !
2022-08-20 08:37 AM
Hi did you figure out how to operate calendar mode? I tried with the end node example but the time won't update
