STM32WBA52 programming on custom board
suvendusahux
I am trying to detect my stm32wba52cg bare chip with onboard stlink as external programmer from a discoveryboard but its showing this msg-
Can not connect to target!
Please select "Connect Under Reset" mode from Target->Settings menu and try again.
If you're trying to connect to a low frequency application , please select a lower SWD Frequency mode from Target->Settings menu.
No target connected.
this are my connection for programming my wba52 controller-
discovery stlink                    stm32wba52
swdio                                          swdio
swclk                                           swclk
nrst                                               rst
3.3 (from discovery board)           3.3
gnd                                               gnd
3 REPLIES 3
Andrew Neil
Evangelist III
What do you mean by that - Literally a bare chip; no PCB at all?  A custom PCB ? Other?
A custom pcb with stmwba52.
Thanks - I updated the title to reflect that.
Please post the schematic of your board.
Some good, clear photos of your setup would also help.
https://community.st.com/t5/community-guidelines/how-to-write-your-question-to-maximize-your-chances-to-find-a/ta-p/575228
