STM32WB BLE SHCI_SUB_EVT_CODE_READY Event is NOT received
Amogh
I am trying to figure out a root cause for a weird unexplainable error on STM32WB with BLE Stack.
In our application, we have BLE stack fully functional, but every now and then, when we make a small change, like adding a debug line, APPE_SysUserEvtRx callback function doesn't receive a SHCI_SUB_EVT_CODE_READY event.
If we move the change couple of lines down, some times this works, some time it doesn't. Its really very frustrating, as I have not been able to figure out what is causing this issue?
Any help/pointer is much appreciated.
17 REPLIES 17
Amogh
I would like to explain the problem a little bit more if possible.
BLE Stack works fine, but when I make small changes, ie uncomment line 1002, and 1003, I DO NOT get a SHCI_SUB_EVT_CODE_READY event.
0693W00000LwroYQAR.pngWe are using RTOS, with BLE co-processor binary version 1.13
Can anyone from ST please provide some insights as to what might be the cause of this behavior?
Amogh
 Hi Remi, @Remi QUINTIN​
I was wondering if you can please provide some guidance on why
APPE_SysEvtReadyProcessing()
receives
p_sys_ready_event->sysevt_ready_rsp == FUS_FW_RUNNING
instead of
p_sys_ready_event->sysevt_ready_rsp == WIRELESS_FW_RUNNING
when I make small non-essential /non BLE related changes in the app_ble.c or custom_app.c, or custom_stm.c.
Remy ISSALYS
What is happening when SHCI_SUB_EVT_CODE_READY event is not received ? Can you stop the debugger and look where are in the code ? Check call stack and logs please.
Where is your ad_data declaration ?
Which version are you using ? If it's 1.13.0, can you retry with the latest release v1.13.3 please.
Your last comment told about a second issue ?
Best Regards
Amogh
Thank you for responding!
ad_data is declared in app_ble.c, and I am just trying to change the local_name of the device, based on Mac Address. The problem is not just related to ad_data because even when I try to write to a characteristic and call a local function, SHCI_SUB_EVT_CODE_READY isn't received. I am not sure why and how something in the BLE thread can interfere and prevent the thread from even starting up.
Please see declaration of ad_data.
uint8_t ad_data[22] = {
    2, AD_TYPE_TX_POWER_LEVEL, 6 /* 6dBm */, /* Transmission Power */
    9, AD_TYPE_COMPLETE_LOCAL_NAME, '9','0','x', 'X', 'X', 'X', 'X', 'X',  /* Complete name */
    3, AD_TYPE_16_BIT_SERV_UUID_CMPLT_LIST, 0x0D, 0x18,
    4, AD_TYPE_MANUFACTURER_SPECIFIC_DATA, 0x30, 0x00, 0x00 /*  */,
step 1: when everything is working, programs jumps into the appe_Tl_Init below
static void appe_Tl_Init( void )
  TL_MM_Config_t tl_mm_config;
  SHCI_TL_HciInitConf_t SHci_Tl_Init_Conf;
  /**< Reference table initialization */
  TL_Init();
  MtxShciId = osMutexNew( NULL );
  SemShciId = osSemaphoreNew( 1, 0, NULL ); /*< Create the semaphore and make it busy at initialization */
  /** FreeRTOS system task creation */
  ShciUserEvtProcessId = osThreadNew(ShciUserEvtProcess, NULL, &ShciUserEvtProcess_attr);
  /**< System channel initialization */
  SHci_Tl_Init_Conf.p_cmdbuffer = (uint8_t*)&SystemCmdBuffer;
  SHci_Tl_Init_Conf.StatusNotCallBack = APPE_SysStatusNot;
  shci_init(APPE_SysUserEvtRx, (void*) &SHci_Tl_Init_Conf);
  /**< Memory Manager channel initialization */
  tl_mm_config.p_BleSpareEvtBuffer = BleSpareEvtBuffer;
  tl_mm_config.p_SystemSpareEvtBuffer = SystemSpareEvtBuffer;
  tl_mm_config.p_AsynchEvtPool = EvtPool;
  tl_mm_config.AsynchEvtPoolSize = POOL_SIZE;
  TL_MM_Init( &tl_mm_config );
  TL_Enable();
  return;
step 2: and then into osKernelStart() function
osStatus_t osKernelStart (void) {
  osStatus_t stat;
  if (IS_IRQ()) {
    stat = osErrorISR;
  else {
    if (KernelState == osKernelReady) {
      /* Ensure SVC priority is at the reset value */
      SVC_Setup();
      /* Change state to enable IRQ masking check */
      KernelState = osKernelRunning;
      /* Start the kernel scheduler */
      vTaskStartScheduler();
      stat = osOK;
    } else {
      stat = osError;
  return (stat);
step 3: and then the startup event is received
static void APPE_SysUserEvtRx( void * pPayload )
  TL_AsynchEvt_t *p_sys_event;
  WirelessFwInfo_t WirelessInfo;
  p_sys_event = (TL_AsynchEvt_t*)(((tSHCI_UserEvtRxParam*)pPayload)->pckt->evtserial.evt.payload);
  /* Read the firmware version of both the wireless firmware and the FUS */
  SHCI_GetWirelessFwInfo( &WirelessInfo );
  APP_DBG_MSG("Wireless Firmware version %d.%d.%d\n", WirelessInfo.VersionMajor, WirelessInfo.VersionMinor, WirelessInfo.VersionSub);
  APP_DBG_MSG("Wireless Firmware build %d\n", WirelessInfo.VersionReleaseType);
  APP_DBG_MSG("FUS version %d.%d.%d\n\n", WirelessInfo.FusVersionMajor, WirelessInfo.FusVersionMinor, WirelessInfo.FusVersionSub);
  switch(p_sys_event->subevtcode)
  case SHCI_SUB_EVT_CODE_READY:
    APPE_SysEvtReadyProcessing(pPayload);
    break;
step 4: and then wireless firmware starts
static void APPE_SysEvtReadyProcessing( void * pPayload )
  SHCI_C2_Ready_Evt_t *p_sys_ready_event;
  SHCI_C2_CONFIG_Cmd_Param_t config_param = {0};
  uint32_t RevisionID=0;
  p_sys_ready_event = (SHCI_C2_Ready_Evt_t*) p_sys_event->payload;
  if(p_sys_ready_event->sysevt_ready_rsp == WIRELESS_FW_RUNNING)
    * The wireless firmware is running on the CPU2
    APP_DBG_MSG("SHCI_SUB_EVT_CODE_READY - WIRELESS_FW_RUNNING \n");
but when I make changes to the BLE thread - like uncomment
line 1003: ad_data[12] = 'j'
breakpoint/function in step3 is never hit.
I was initially on version 1.13.0.5 but even after updating to 1.13.3.2, I get the issue.
Remy ISSALYS
When SHCI_SUB_EVT_CODE_READY event is not received, can you stop your debugger, take a screenshot of the call stack please and look what the CPU is doing ?
Can you also take a screenshot of the memory content at 0x20030000 (first 4 word of 32 bits) ?
Can you add a breakpoint in shci_notify_asynch_evt function and check if you see the event or not ?
Best Regards
Amogh
0693W00000LxHBmQAN.jpg0693W00000LxHBrQAN.jpgHi,
  • I am not sure how to pinpoint the state when SHCI_SUB_EVT_CODE_READY is NOT received. Can you please explain which function should I set the breakpoint on?
  • I added a breakpoint shci_notify_asynch_evt but this breakpoint does NOT get hit.
  • I noticed, when init command is received, it is right after scheduler is started with osKernelStart() function in main.c
  • This last image shows the callstack, when I remove the change, and rebuild and reflash, and init command is received.
Amogh
The Rootcause of the problem seems to the the IPCC Rx interrupt not being triggered. What I dont understand is why would a change in BLE thread stop this from happening?
Thanks!
  * @brief This function handles IPCC RX occupied interrupt.
void IPCC_C1_RX_IRQHandler(void)
  /* USER CODE BEGIN IPCC_C1_RX_IRQn 0 */
  /* USER CODE END IPCC_C1_RX_IRQn 0 */
  HAL_IPCC_RX_IRQHandler(&hipcc);
  /* USER CODE BEGIN IPCC_C1_RX_IRQn 1 */
  /* USER CODE END IPCC_C1_RX_IRQn 1 */
Amogh
I was digging in to find the problems root cause and I dont know if this helps but also putting a breakpoint in the Reset_Device(Void) function below , and then pressing play, kills the any interrupt on IPCC. I am using IAR in debug mode, and have compiler optimizations to high.
static void Reset_Device( void )
#if ( CFG_HW_RESET_BY_FW == 1 )
  Reset_BackupDomain();
  Reset_IPCC();
#endif /* CFG_HW_RESET_BY_FW */
  return;
This problem is really odd!
Amogh
Hi Remy,
I am using IAR and I recently learned that setting compiler optimizations to HIGH also causes IRCC to miss any interrupts. Does this help narrow down the issue? When I turn optimizations to LOW, IRCC is able to catch the interrupts.
