Send and receive data via ZigBee on STM32WB55
YYoyo.1
Which Cluster may use to send and receive data or string between Router and Coord?
And how do I coding for that.
Thank you.
RomainR.
Hello @YYoyo.1 (Community Member)
Using Custom long string cluster example.
You can refer to following ZigBee example in latest \STM32Cube_FW_WB_V1.15.0\Projects\P-NUCLEO-WB55.Nucleo\Applications\
Zigbee_custom_ls_Client_Router
Zigbee_custom_ls_Server_Coord
Best rfegards,
Romain,
In order to give better visibility on the answered topics, please click on 'Select as Best' on the reply which solved your issue or answered your question. See also 'Best Answers'
RomainR.
Best rfegards,
Romain,
Thank you, it work successfully.
Best regards.
Yoyo
