PM0271 wrong RF frequency formula and table
Motla1
In programming manual PM0271 - STM32WB BLE stack programming guidelines
https://www.st.com/resource/en/programming_manual/pm0271-stm32wb-ble-stack-programming-guidelines-stmicroelectronics.pdf
In section 2.2
The correct formula should be : (2402 + k*2) MHz, where 0 ≤ k ≤ 39
The table 1 is not correct as well, it should conform to the formula.
e.g. Channel 10 = 2422 Mhz
Tested in hardware on NUCLEO-WB15CC using BLE_LLD_StartTone
3 REPLIES 3
KDJEM.1
Hello @Motla​ ,
I confirm that the (1) formula is not aligned with the values in table1 in the PM0271.
I reported this issue internally.
I will get back to you with more details as soon as possible.
Internal ticket number: 134452 (This is an internal tracking number and is not accessible or usable by customers).
Kaouthar
KDJEM.1
Hi @Motla​ ,
I confirm that the correct formula is (2402 + 2*k) MHz, where 0 ≤ k ≤ 39,
Kaouthar
Motla1
Still not corrected in the Rev 7 - April 2023 release of the document...
