NUCLEO WL55JC1 dead?
‎2023-08-02 9:08 AM
Hi, I was working as usual with my NUCLEO WL55JC1 board, powered from external 3.3V. Everything was working correctly and I turned the power suplly off, after turning it on again (next day), the board didn't work. I know the program is not runnin because I had a blinking LED that remains off. If I try to load the program to the board again I get teh following errors:
Error in final launch sequence:
Error message from debugger back end:
Error finishing flash operation
Failed to execute MI command:
When I connect the board to the computer, the biclor LED flashes and then remains red, indicating initialization between the PC and STLINK-V3E is complete, after fail uploading the program the led remains green indicating communication finished and successful but no debug session was even started.
I´d like to know if my board is dead or if there is something I can try to make it work
STM32WL series
‎2023-08-03 11:24 AM
Hi, I managed to make it work again, here is what happened:
I used CubeProgrammer to access the flah memory, and even though it showed an error on the read operation, it allowed me to perform a full chip erase. After doing that I was able to upload my code to the board again, however, the radio part was not working. I realised that the board was restarting "randomly" and eventually I figured out that it was just after sending data via LoRa. Actually the MCU was generating a reset jus after entering stop2 mode, which was entered after sending a radio packet, so it was indeed sendig data but could´t receve the response because the reset generated when it was supposed to enter low power mode. To solve that I changed the state of the flash option byte nRST_STOP which precisely makes the either MCU restart or keep running when entering low power mode.
That's how I worked around this issue and it has been working ok since then. I suppose the flash content got corrupted but I don't know what the cause might have been.
Thank you very much for your support
‎2023-08-03 3:39 AM
Hello @JPablo1 and welcome to ST Community.
I suggest you to change the pin of boot and try again.
Best Regards.
Issam
