Is there a way to add more than 5 BLE characteristics per service
nollstead
Hello, I'm configuring an STM32WB55CEU6 in STM32CubeIDE and am setting up the BLE part now and I noticed that the IDE only let's me setup 5 characteristics per service.  In my application (a remote control) I need about 15 characteristics.  Is there a way to increase that number?
_Joe_
Hi Nollstead,
With STM32WB, it is not possible to add more than 5 characteristics  per service using STM32CubeMX. The solution would be to add the other characteristic manually without using STM32CubeMX.
This limitation has been improved on STM32WBA, with a maximum of 25 characteristics  per service.
BR, Joé
3 REPLIES 3
_Joe_
Hi Nollstead,
BR, Joé
Thank you for your answer, I suspected that was the case and this explains why I saw references to 25 in a few places.  Right now since I'm an STM32 newbie I'd like to stick to STM32CubeIDE so it'd probably work to spread those across three services so I'll try that.
_Joe_
Yes, it would seem to be a good solution to keep your project compatible with the Cube ecosystem.
BR, Joé
