Is P-NUCLEO-LRWAN1 still works with I-CUBE-LRWAN
New.Fish
We have two "P-NUCLEO-LRWAN1" bought several years ago, it is obsolete from ST,
I try to play with LoRa, is "I-CUBE-LRWAN" still can work with those kit?
3 REPLIES 3
Imen.D
Hello @New.Fish​ ,
I-CUBE-LRWAN should still work with P-NUCLEO-LRWAN1 kits.
Imen
Imen
Hi lmen,
Try to download "I-CUBE-LRWAN", but it keeps report erro message " Bad Gateway
The proxy server received an invalid response from an upstream server",
It is the same error in my office or at home, something wrong with ST server?
Sam
https://www.st.com/en/evaluation-tools/p-nucleo-lrwan1.html
If we're talking about the NUCLEO with the SEMTECH SX1272 board, you'll need to build current versions of the firmware, and connect to suitable gateways/servers.
The old TTN is deprecated so might need to revisit all the links in the chain.
