2022-10-10 02:45 PM
Hello Everyone,
Currently, I am working with the board Nucleo-WL55JC1. I wonder if it is possible to isolate and measure either current or voltage of a component (RF or a peripheral for example) on my development board?. My main goal is to seperately measure power consumption of a component on my board.
Hope to see your help.
Thank you, Huy Nguyen.
2022-10-10 07:19 PM
https://www.st.com/en/evaluation-tools/nucleo-wl55jc.html#cad-resources
Would suggest dissecting the schematic to understand the parts/nets
There look to be a lot of solder bridges allowing you to measure currents on different supplies
2022-10-10 07:19 PM
2022-10-12 12:48 AM
Indeed, by seeing the schematic as well as the datasheet, there are some solder bridges that are used for measuring components individually.
Thank you,
Huy Nguyen.
