2025-03-21 2:03 AM
I want to use CLion for development, which requires CMake, and I've been struggling with integrating the X-CUBE-MATTER package in it.
Globbing all files with
file(GLOB_RECURSE src_files "Middlewares/*.c" "Middlewares/*.cpp" "Drivers/*.c" "Drivers/*.cpp")
produces a binary significantly larger than FLASH and still fails to compile because it includes various examples and templates.
Another option I thought of is manually adding all the necessary files, however that seems like a herculean task.
Is there an easier way to go on about this (perhaps ST is already working on it)?
Thank you for your reply.
2025-04-11 9:06 AM
I actually managed to get it working by exporting all c/cpp files from the .project file from e.g. Projects\STM32WB5MM-DK\Applications\Matter\Lighting-App\STM32CubeIDE
2025-04-10 1:04 PM
Hello @vohorci
For now, there is not a recommended way for this specific request.
Best Regards.
STTwo-32
2025-04-11 9:06 AM
