Inquiry on STM32WLE5CC with LORA Received Signal Strength Indicator (RSSI) accuracy
Jack_Kow
Hello ST experts and everyone,
I am a beginner on using the STM32WLE5CC series and need some support.
Currently, I have assigned to carry out verification test of STM32WLE5CC series on LORA Received Signal Strength Indicator (RSSI) and successfully set up a test system on detecting the LORA RSSI value through firmware.
However, with the requirement of resource to support my test system, LORA Received Signal Strength Indicator (RSSI) accuracy (+/- ? dBm) (on receiver side) is important to verify my test system on detecting the LORA RSSI value through firmware. Therefore, I would like to ask any information or other references on it.
Would apologise that I could not provide the full design of my test system due to policy and greatly appreciate to have any support or opinion on my inquiry.
Thanks.
Best Regards,
Jack
STTwo-32
Hello @Jack_Kow
For such a specific use case, it will be a good idea to have a contact with one of our FAEs. They can ensure you a direct and dedicated support.
Best Regards.
STTwo-32
1 REPLY 1
STTwo-32
Hello @Jack_Kow
Best Regards.
STTwo-32
