I am making a LoRa application-based project using STM32WLE5. The confusing part for me is which power source I should select "HIGH POWER' or "LOW POWER' for RF. The band is EU868 (South Africa).
Options
‎2022-11-21 4:16 AM
Options
‎2022-11-21 5:02 AM
Typically there are two paths, do you need the PA (Power Amplifier), or the broader range of power settings with both paths?​
Options
‎2022-11-21 8:31 PM
Yes, we need the Power Amplifier, and can you please elaborate on the second option?
