How to run STM32Wl55 LoRa transmit using internal clock, without external crystal?
SK.20
1 REPLY 1
Uwe Bonnes
Principal III
You can not run without external crystal. Frequency tolerance and stability is too bad for reliable communication. For low rate LORA you even need temerature compensated oscillators with tightend specification.
