How to run multiple different models on different elements in a node??
2020-09-16 3:56 AM
I am using STM32WB55 Nucleo Pack (STM32WB55RGV6 MCU) and STM32Cube_FW_WB_V1.3.0 SDK, I uploaded BLE_MeshLightingDemo code (without any edit) and provisioned the node using ST BLE Mesh app , all the elements in a node shows simillar models.
I want to to run different models on different elements in a single node, help me please....
2020-09-25 12:07 AM
Hi EMECH ,
Thanks for helping me.
I changed the configurations as you mentioned,
#define ENABLE_GENERIC_MODEL_SERVER_ONOFF (7) //element 1 + element 2 + element 3
#define ENABLE_GENERIC_MODEL_SERVER_LEVEL (2) //element 2
And:
#define APPLICATION_NUMBER_OF_ELEMENTS 3
The provisioning completed successfully, but Couldn't configure the node.
The BLE Mesh app trying to get Device Composition Data(Loading Device Composition Data),but it can't.
2020-09-25 2:17 AM
I have done the test with success on the cubeWB FW package V1.8 package with an Iphone 8 on IOS 14.0.
What is your environment configuration ?
Best regards.
2020-09-25 2:48 AM
I'm using STM32Cube_FW_WB_V1.8.0 package with an Android Smartphone(VIVO) with Android 9 version
I'm using BLE_MeshLightingPRFNode project from the package.
I changed only the configurations as you mentioned in mesh_cfg_usr.h file
And:
Is any other changes required in the code??
2020-09-25 3:16 AM
Serial printed data is
Unprovisioned device
PB-ADV Enabled
PB-GATT Enabled
Feature: Relay Enabled
Feature: Proxy Enabled
Feature: Friend Enabled
Models data will be saved in Flash
Number of Elements enabled: 3
Neighbour Table is enabled
Generic On Off Server Model enabled
Generic Level Server Model enabled
Light Lightness Server Model enabled
BLE-Mesh Lighting Demo v1.12.008
BLE-Mesh Library v01.12.008
BLE Stack v1.8.0 Branch=0 Type=5
FUS v1.0.2
BD_MAC Address = xxxxxxxxxxxxxx
UUID Address = [f8] [1d] [4f] [ae] [7d] [ec] [4b] [53] [a1] [54] [b5] [24] [08] [26] [e1] [c0]
211667 Appli_BleUnprovisionedIdentifyCb - Unprovisioned Node Identifier received: 0a
212667 Appli_BleAttentionTimerCb -
213667 Appli_BleAttentionTimerCb -
214667 Appli_BleAttentionTimerCb -
215667 Appli_BleAttentionTimerCb -
216667 Appli_BleAttentionTimerCb -
217667 Appli_BleAttentionTimerCb -
218667 Appli_BleAttentionTimerCb -
220407 Appli_BleAttentionTimerCb -
221407 Appli_BleAttentionTimerCb -
Device is provisioned by provisioner
222407 Appli_BleAttentionTimerCb -
2020-09-25 5:58 AM
OK, the troubles you have with multi element during provisoning with Android ST BLE Mesh App is solved in the next Android ST BLE Mesh App and the STM32Cube_FW_WB_V1.9.0 normally availables at the end of this month.
With the IOS ST BLE Mesh App and the STM32Cube_FW_WB_V1.8.0 you do not have this kind of trouble.
In the meantime, perhaps you can have the opportunity to use the IOS ST BLE Mesh App ?
Best regards.
2020-09-27 9:30 PM
Hi EMECH,
We tried IOS ST BLE Mesh App with an Iphone 6s on IOS 14.0 and the STM32Cube_FW_WB_V1.8.0(three elements per node) , but the same problem occurred again. Couldn't configured the node after provisioning.
2020-09-28 6:31 AM
OK, as I have written I did not have this trouble with STM32Cube_FW_WB_V1.8.0 and IOS ST BLE Mesh App with an Iphone 8 on IOS 14.0.
Do you have the same trouble during Loading Device Composition Data ?
Did you try to provision many times ?
Best regards
2020-09-28 8:47 PM
Yes, I have the same trouble during Loading Device Composition Data, So configuration failed.
I tried a lot of times, but the result was same.
Here is my mesh_usr_cfg.h file.
Would you please suggest me if there any other changes required?
2020-10-02 1:28 AM
Please try with the new STM32Cube_FW_WB_V1.9.0 published on https://www.st.com/en/embedded-software/stm32cubewb.html
This release includes a lot of modifications related to the described troubles.
Do not forget to update the BLE stack, see the how to proceed in STM32Cube_FW_WB_V1.9.0/Projects/STM32WB_Copro_Wireless_Binaries/STM32WB5x/Release_Notes.html.
Best regards.
2020-10-04 10:28 PM
Thanks for your help.
It worked successfully with 3 elements per node.
Is there any option to increment the number of elements per node greater than three in STM32Cube_FW_WB_V1.9.0 version??
Why ST always limiting number of elements to 3 even BLE mesh node supports more than 10 elements???
