How to change transmit power in runtime
KimiHu
Hi all,
If I want to increase transmit power when press button, how to do it?
1. Do I stop or DeInit something?
2. which API can change power?
Thank you
3 REPLIES 3
What chip?
KimiHu
I use NUCLEO-WL55JC1 EVM
STTwo-32
Hello @KimiHu
To change the TX_Output power on a button Click, I suggest you create an interrupt on the press of the Button where you change the TX_OUTPUT_POWER (this parameter is declared on the subghz_phy_app.h).
Best Regards.
STTwo-32
