2023-09-16 08:05 AM
I am currently experimenting with the LL data length extension feature on STM32WB55.
I want to increase max TX length in link layer packet.
I would appreciate it if you could tell me how to increase max TX length.
(Looking at the current LL_LENGTH_RSP packet, Max. RX octets: 251 and Max TX octets: 27 are given.)
2024-06-20 07:40 AM
Hello JLee,
Have you found a solution to this? We are bashing our heads on this issue too.
Explicitly setting hci_le_set_data_length to 251 will result in hci_le_data_length_change_event->MaxRxOctets = 27
Both sides support data length extension, we verified.
Can it be an issue on a master side? Tried multiple Android devices with exactly the same result.
