How do I change the priorities for the TIM2?
‎2021-06-10 2:07 AM
Hi, I'm using STM32WB55x series mcu, I wanna know how I should configure/change the relevant priority for the TIM2?
In the old days we use this:
void NVIC_Configuration(void)
NVIC_InitTypeDef NVIC_InitStructure;
NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
NVIC_InitStructure.NVIC_IRQChannel=TIM2_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority=0;
NVIC_InitStructure.NVIC_IRQChannelSubPriority=1;
NVIC_InitStructure.NVIC_IRQChannelCmd=ENABLE;
NVIC_Init(&NVIC_InitStructure);
I don't know what we should do now given it's the day and age of HAL and CubeMX.
What should I do? If there's a register manipulating solution, it would be better.
STM32WB series
TIM
‎2021-06-10 2:22 AM
Is that SPL? Isn't it open source? Look at what NVIC_Init() does.
‎2021-06-10 7:19 AM
If you have old code, it will still work. You can simply keep using it if you want.
> What should I do?
For example:
HAL_NVIC_SetPriorityGrouping(NVIC_PRIORITYGROUP_4);
HAL_NVIC_SetPriority(PVD_PVM_IRQn, 0, 0);
HAL_NVIC_EnableIRQ(PVD_PVM_IRQn);
‎2021-06-10 7:28 AM
... and then also look at what exactly those three HAL_*** "functions" do.
‎2021-06-10 9:40 AM
So these days, as TDK wrote, the "HAL" library uses NVIC_PRIORITYGROUP_4.
Do not use sub-priorities, unless there's a strong requirement.
--pa
‎2021-06-10 7:17 PM
Well the thing is, SPL doesn't appear to be a part of the keil's "pack", and I don't know where to obtain the relevant SPL source code, and I don't know which header file to include.
‎2021-06-10 7:17 PM
Thank you, that's actually my intention.
I will then use direct manipulation on the registers.
‎2021-06-10 7:19 PM
I don't know where to get the SPL.
And thanks for the tip!
‎2021-06-10 7:52 PM
https://www.st.com/en/embedded-software/stm32-standard-peripheral-libraries.html
‎2021-06-10 10:04 PM
ST ceased to port SPL to newer families once Cube/HAL was around, but NVIC is part of the processor core, so you can use SPL of any product using the same Cortex-M core for this purpose.
But you don't need to look at SPL, see below.
That's what SPL does. But I don't recommend you to do that. As NVIC is part of the core, once you use the standard CMSIS-mandated headers (which you do by #include "stm32fxxxx" where xxxx is the STM32 model you are using; you may include this indirectly if you use any "library") so use the standard CMSIS functions for NVIC. That's what Cube/HAL does, anyway.
NVIC_SetPriorityGrouping(3); // SCB_AIRCR.PRIGROUP == 0b011 for 4 bit (maximum) group priority in STM32 with Cortex-M4 core
NVIC_SetPriority(PVD_PVM_IRQn, 0); // 0 - highest, 15 - lowest
Read NVIC design hints and tips and Binary point subchapters in PM0214.
