Function pack FP-SNS-DATAPRO1 Version 1.1.0 zip file corrupt
Joerg Wagner
Senior III
Can someone please provide a working download file for "STM32Cube function pack for STEVAL-PROTEUS1 sensor datalog and file transfer over BLE and USB"?
The ZIP-File Version 1.1.0 is corrupt.
It cannot be extracted neither on Windows, Linux or Mac.
To be honest it's possible to extract under Linux.
But the archive just contains 82 files instead of 2408 files like in Version 1.0.0.
Thank you.
Peter BENSCH
Since I don't have a MAC or Linux at hand, I can only try it with Win11, where I can unpack it perfectly with 7z. If the file size and checksum are correct, there must be something wrong with your unpacker.
4 REPLIES 4
Peter BENSCH
I have just tested it again - the download works perfectly, the ZIP can be unpacked without errors and it contains 2508 files and 492 folders. If the size of your ZIP differs from 65'459'303 bytes, you should download it again.
The SHA-256 checksum of version 1.1.0 is by the way:
9A7146747F38DFF837CDD3C3AA34F0AE0BDE460FA518E7BAD130C3D3B9BD6335
Hope that helps?
/Peter
I have the same checksum and
joerg@razer:~/temp$ sha256sum en.fp-sns-datapro1.zip
9a7146747f38dff837cdd3c3aa34f0ae0bde460fa518e7bad130c3d3b9bd6335  en.fp-sns-datapro1.zip
joerg@razer:~/temp$ ls -al en.fp-sns-datapro1.zip
-rw-r--r-- 1 joerg 65459303 Dez 13 13:18 en.fp-sns-datapro1.zip
joerg@razer:~/temp$ unzip en.fp-sns-datapro1.zip
After unpacking:
joerg@razer:~/temp$ cd STM32CubeFunctionPack_DATAPRO1_v1.1.0/
joerg@razer:~/temp/STM32CubeFunctionPack_DATAPRO1_v1.1.0$ tree
├── Documentation
├── Drivers
│   ├── BSP
│   │   ├── Components
│   │   │   ├── Common
│   │   │   │   └── _htmresc
│   │   │   ├── iis2dlpc
│   │   │   ├── iis3dwb
│   │   │   ├── ism330dhcx
│   │   │   ├── mx66l2g
│   │   │   └── stts22h
│   │   │       └── _htmresc
│   │   └── STEVAL-PROTEUS
│   │       └── _htmresc
│   ├── CMSIS
│   │   ├── Core
│   │   │   ├── Include
│   │   │   └── Template
│   │   │       └── ARMv8-M
│   │   ├── Core_A
│   │   │   ├── Include
│   │   │   └── Source
│   │   ├── Device
│   │   │   └── ST
│   │   │       └── STM32WBxx
│   │   │           ├── _htmresc
│   │   │           ├── Include
│   │   │           └── Source
│   │   │               └── Templates
│   │   │                   ├── arm
│   │   │                   │   └── linker
│   │   │                   ├── gcc
│   │   │                   │   └── linker
│   │   │                   └── iar
│   │   │                       └── linker
│   │   ├── DSP
│   │   │   ├── Examples
│   │   │   │   └── ARM
│   │   │   │       ├── arm_class_marks_example
│   │   │   │       │   └── RTE
│   │   │   │       │       └── Device
│   │   │   │       │           ├── ARMCM0
│   │   │   │       │           ├── ARMCM3
│   │   │   │       │           ├── ARMCM4_FP
│   │   │   │       │           └── ARMCM7_SP
│   │   │   │       ├── arm_convolution_example
│   │   │   │       │   └── RTE
│   │   │   │       ├── arm_dotproduct_example
│   │   │   │       │   └── RTE
│   │   │   │       ├── arm_fft_bin_example
│   │   │   │       │   └── RTE
│   │   │   │       ├── arm_fir_example
│   │   │   │       │   └── RTE
│   │   │   │       ├── arm_graphic_equalizer_example
│   │   │   │       │   └── RTE
│   │   │   │       ├── arm_linear_interp_example
│   │   │   │       │   └── RTE
│   │   │   │       ├── arm_matrix_example
│   │   │   │       │   └── RTE
│   │   │   │       ├── arm_signal_converge_example
│   │   │   │       │   └── RTE
│   │   │   │       ├── arm_sin_cos_example
│   │   │   │       │   └── RTE
│   │   │   │       ├── arm_variance_example
│   │   │   │       │   └── RTE
│   │   │   │       └── boot
│   │   │   ├── Include
│   │   │   ├── Lib
│   │   │   │   ├── ARM
│   │   │   │   ├── GCC
│   │   │   │   └── IAR
│   │   │   ├── PythonWrapper
│   │   │   │   └── cmsisdsp_pkg
│   │   │   │       └── src
│   │   │   └── Source
│   │   │       ├── BasicMathFunctions
│   │   │       ├── CommonTables
│   │   │       ├── ComplexMathFunctions
│   │   │       ├── ControllerFunctions
│   │   │       ├── FastMathFunctions
│   │   │       ├── FilteringFunctions
│   │   │       ├── MatrixFunctions
│   │   │       ├── StatisticsFunctions
│   │   │       ├── SupportFunctions
│   │   │       └── TransformFunctions
│   │   ├── Include
│   │   ├── NN
│   │   │   ├── Examples
│   │   │   │   ├── ARM
│   │   │   │   │   └── arm_nn_examples
│   │   │   │   │       ├── cifar10
│   │   │   │   │       │   └── RTE
│   │   │   │   │       │       ├── _ARMCM0
│   │   │   │   │       │       ├── _ARMCM3
│   │   │   │   │       │       ├── _ARMCM4_FP
│   │   │   │   │       │       ├── _ARMCM7_SP
│   │   │   │   │       │       ├── Compiler
│   │   │   │   │       │       └── Device
│   │   │   │   │       │           ├── ARMCM0
│   │   │   │   │       │           ├── ARMCM3
│   │   │   │   │       │           ├── ARMCM4_FP
│   │   │   │   │       │           └── ARMCM7_SP
│   │   │   │   │       └── gru
│   │   │   │   │           └── RTE
│   │   │   │   └── IAR
│   │   │   │       └── iar_nn_examples
│   │   │   │           ├── NN-example-cifar10
│   │   │   │           └── NN-example-gru
│   │   │   ├── Include
│   │   │   ├── Scripts
│   │   │   │   └── NNFunctions
│   │   │   └── Source
│   │   │       ├── ActivationFunctions
│   │   │       ├── ConvolutionFunctions
│   │   │       ├── FullyConnectedFunctions
│   │   │       ├── NNSupportFunctions
│   │   │       ├── PoolingFunctions
│   │   │       └── SoftmaxFunctions
│   │   ├── RTOS
│   │   │   └── Template
│   │   └── RTOS2
│   │       ├── Include
│   │       ├── Source
│   │       └── Template
│   └── STM32WBxx_HAL_Driver
│       ├── _htmresc
│       ├── Inc
│       │   └── Legacy
│       └── Src
├── _htmresc
├── Middlewares
│   ├── ST
│   │   ├── PnPLCompManager
│   │   │   ├── _htmresc
│   │   │   ├── Inc
│   │   │   └── Src
│   │   ├── STM32_BLE_Manager
│   │   │   ├── Documentation
│   │   │   │   └── STM32_BLE_Manager_Library.chm
│   │   │   ├── _htmresc
│   │   │   ├── Inc
│   │   │   └── Src
│   │   ├── STM32_USB_Device_Library
│   │   │   ├── Class
│   │   │   │   ├── AUDIO
│   │   │   │   │   ├── Inc
│   │   │   │   │   └── Src
│   │   │   │   ├── BillBoard
│   │   │   │   │   ├── Inc
│   │   │   │   │   └── Src
│   │   │   │   ├── CDC
│   │   │   │   │   ├── Inc
│   │   │   │   │   └── Src
│   │   │   │   ├── CDC_ECM
│   │   │   │   │   ├── Inc
│   │   │   │   │   └── Src
│   │   │   │   ├── CDC_RNDIS
│   │   │   │   │   ├── Inc
│   │   │   │   │   └── Src
│   │   │   │   ├── CustomHID
│   │   │   │   │   ├── Inc
│   │   │   │   │   └── Src
│   │   │   │   ├── DFU
│   │   │   │   │   ├── Inc
│   │   │   │   │   └── Src
│   │   │   │   ├── HID
│   │   │   │   │   ├── Inc
│   │   │   │   │   └── Src
│   │   │   │   ├── MSC
│   │   │   │   │   ├── Inc
│   │   │   │   │   └── Src
│   │   │   │   ├── SensorStreaming_WCID
│   │   │   │   │   ├── _htmresc
│   │   │   │   │   ├── Inc
│   │   │   │   │   └── Src
│   │   │   │   ├── Template
│   │   │   │   │   ├── Inc
│   │   │   │   │   └── Src
│   │   │   │   └── VIDEO
│   │   │   │       ├── Inc
│   │   │   │       └── Src
│   │   │   └── Core
│   │   │       ├── Inc
│   │   │       └── Src
│   │   └── STM32_WPAN
│   │       ├── ble
│   │       │   ├── core
│   │       │   │   ├── auto
│   │       │   │   ├── doc
│   │       │   │   └── template
│   │       │   ├── menu
│   │       │   ├── mesh
│   │       │   │   ├── Inc
│   │       │   │   ├── Library
│   │       │   │   │   └── nofile.txt
│   │       │   │   ├── MeshModel
│   │       │   │   │   ├── Inc
│   │       │   │   │   └── Src
│   │       │   │   ├── PAL
│   │       │   │   │   └── STM32WB
│   │       │   │   └── Src
│   │       │   └── svc
│   │       │       ├── Inc
│   │       │       └── Src
│   │       ├── ble_lld
│   │       │   ├── hal
│   │       │   └── lld
│   │       ├── _htmresc
│   │       ├── interface
│   │       │   └── patterns
│   │       │       └── ble_thread
│   │       │           ├── conf
│   │       │           ├── lhci
│   │       │           ├── shci
│   │       │           ├── tl
│   │       │           └── vcp
│   │       ├── mac_802_15_4
│   │       │   ├── core
│   │       │   │   ├── inc
│   │       │   │   └── src
│   │       │   └── _htmresc
│   │       ├── thread
│   │       │   └── openthread
│   │       │       ├── core
│   │       │       │   └── openthread_api
│   │       │       ├── _htmresc
│   │       │       └── STM32WBxx_OpenThread_API_User_Manual.chm
│   │       ├── utilities
│   │       └── zigbee
│   │           ├── core
│   │           │   ├── inc
│   │           │   └── src
│   │           ├── lib
│   │           ├── platform
│   │           └── stack
│   │               ├── include
│   │               │   ├── extras
│   │               │   ├── mac
│   │               │   ├── zcl
│   │               │   │   ├── general
│   │               │   │   ├── key
│   │               │   │   ├── se
│   │               │   │   ├── security
│   │               │   │   └── st_custom
│   │               │   └── zgp
│   │               ├── sha
│   │               │   └── include
│   │               └── zcl
│   │                   └── st_custom
│   └── Third_Party
│       ├── FatFs
│       │   ├── doc
│       │   │   ├── en
│       │   │   ├── ja
│       │   │   └── res
│       │   └── src
│       │       ├── drivers
│       │       └── option
│       ├── FreeRTOS
│       │   └── Source
│       │       ├── CMSIS_RTOS
│       │       ├── CMSIS_RTOS_V2
│       │       ├── include
│       │       └── portable
│       │           ├── Common
│       │           ├── GCC
│       │           │   ├── ARM_CM0
│       │           │   ├── ARM_CM23
│       │           │   │   ├── non_secure
│       │           │   │   └── secure
│       │           │   ├── ARM_CM23_NTZ
│       │           │   │   └── non_secure
│       │           │   ├── ARM_CM3
│       │           │   ├── ARM_CM33
│       │           │   │   └── secure
│       │           │   ├── ARM_CM33_NTZ
│       │           │   ├── ARM_CM3_MPU
│       │           │   ├── ARM_CM4F
│       │           │   ├── ARM_CM4_MPU
│       │           │   ├── ARM_CM7
│       │           │   │   └── r0p1
│       │           │   └── ARM_CM7_MPU
│       │           │       └── r0p1
│       │           ├── IAR
│       │           │   ├── ARM_CM0
│       │           │   ├── ARM_CM23
│       │           │   │   └── secure
│       │           │   ├── ARM_CM3
│       │           │   ├── ARM_CM33
│       │           │   │   └── secure
│       │           │   ├── ARM_CM4F
│       │           │   ├── ARM_CM7
│       │           │   │   └── r0p1
│       │           │       └── r0p1
│       │           ├── Keil
│       │           │   └── See-also-the-RVDS-directory.txt
│       │           ├── MemMang
│       │           ├── RVDS
│       │           │   ├── ARM_CM0
│       │           │   ├── ARM_CM3
│       │           │   ├── ARM_CM4F
│       │           │   ├── ARM_CM7
│       │           │   │   └── r0p1
│       │           │       └── r0p1
│       │           └── Tasking
│       │               └── ARM_CM4F
│       └── parson
│           └── _htmresc
├── Projects
│   ├── STM32WB5MMG-Proteus
│   │   └── Applications
│   │       ├── BLE_FUOTA
│   │       │   └── Binary
│   │       └── DATAPRO1
│   │           ├── Binary
│   │           ├── BLE_Core
│   │           │   └── App
│   │           ├── Core
│   │           │   ├── Inc
│   │           │   └── Src
│   │           ├── EWARM
│   │           ├── FATFS
│   │           │   ├── App
│   │           │   └── Target
│   │           ├── HSD_Core
│   │           │   ├── _htmresc
│   │           │   ├── Inc
│   │           │   └── Src
│   │           ├── _htmresc
│   │           ├── MDK-ARM
│   │           ├── Patch
│   │           ├── PnPL
│   │           │   ├── Inc
│   │           │   └── Src
│   │           ├── STM32CubeIDE
│   │           │   └── Application
│   │           │       └── User
│   │           │           ├── Core
│   │           │           │   └── Src
│   │           │           └── Startup
│   │           ├── STM32_WPAN
│   │           │   ├── App
│   │           │   └── Target
│   │           └── USB_Device
│   │               ├── App
│   │               └── Target
│   └── STM32WB_Copro_Wireless_Binaries
│       └── STM32WB5x
│           └── stm32wb5x_BLE_Stack_full_fw.bin
└── Utilities
    ├── lpm
    │   └── tiny_lpm
    │       └── _htmresc
    ├── sequencer
    │   ├── html
    │   │   ├── search
    │   │   │   └── typedefs_0.js
    │   └── _htmresc
    └── SwUtilities
        └── HS_Datalog
            ├── cli_example
            │   ├── bin
            │   ├── bin_64
            │   ├── _htmresc
            │   ├── lib
            │   │   ├── hs_datalog
            │   │   ├── hs_datalog_64
            │   │   └── thirdParty
            │   │       └── nlohmann
            │   ├── linux_setup
            │   │   └── 30-hsdatalog.rules
            │   └── raspberry_setup
            ├── HSDPython_SDK
            │   ├── examples
            │   │   ├── _htmresc
            │   │   ├── __init__.py
            │   │   └── Views
            │   │       ├── __init__.py
            │   │       └── __pycache__
            │   ├── linux_setup
            │   ├── st_hsdatalog
            │   │   ├── build.sh
            │   │   ├── dist
            │   │   │   ├── GUI
            │   │   │   └── noGUI
            │   │   ├── __init__.py
            │   │   ├── st_hsdatalog
            │   │   │   ├── HSD
            │   │   │   │   ├── __init__.py
            │   │   │   │   ├── model
            │   │   │   │   │   └── __init__.py
            │   │   │   │   └── utils
            │   │   │   ├── HSD_GUI
            │   │   │   │   ├── UI
            │   │   │   │   │   ├── images
            │   │   │   │   │   │   └── __init__.py
            │   │   │   │   └── Widgets
            │   │   │   ├── HSD_link
            │   │   │   │   ├── communication
            │   │   │   │   │   ├── ADEV_HSD
            │   │   │   │   │   ├── __init__.py
            │   │   │   │   │   ├── libhs_datalog
            │   │   │   │   │   │   ├── 32bit
            │   │   │   │   │   │   ├── 64bit
            │   │   │   │   │   │   ├── linux
            │   │   │   │   │   │   └── raspberryPi
            │   │   │   │   │   ├── PnPL_HSD
            │   │   │   │   │   └── STWIN_HSD
            │   │   │   ├── HSD_utils
            │   │   └── st_hsdatalog.egg-info
            │   │       ├── GUI
            │   │       │   ├── dependency_links.txt
            │   │       │   ├── requires.txt
            │   │       │   └── top_level.txt
            │   │       └── noGUI
            │   └── st_pnpl
            │       ├── build.sh
            │       ├── dist
            │       ├── __init__.py
            │       ├── st_pnpl
            │       │   ├── DTDL
            │       │   │   ├── dtmi
            │       │   │   │   └── appconfig
            │       │   │   │       ├── b_u585i_iot02a
            │       │   │   │       ├── nucleo_h7a3zi_q
            │       │   │   │       │   └── x_nucleo_iks02a1
            │       │   │   │       ├── nucleo_u575zi_q
            │       │   │   │       ├── steval_mkboxpro
            │       │   │   │       ├── steval_stwinbx1
            │       │   │   │       └── steval_stwinkt1b
            │       │   └── __init__.py
            │       └── st_pnpl.egg-info
            │           └── top_level.txt
            ├── PROTEUS_batch_file_examples
            │   └── Acquisition Example
            │       └── STTS22H_TEMP.dat
            └── PROTEUS_config_examples
492 directories, 82 files
Like I said, tried again also on an iMac and Win11.
Peter BENSCH
Crazy, it's magic.
