2023-09-07 12:40 AM
Hello I need help to update my fus in stm32wb10ccu5.
If there is any expert available from Stm please reply.
2023-09-07 12:51 AM
2023-09-07 12:51 AM
2023-09-09 12:33 AM
Ok thanks for your solution. Can you kindly check my circuit diagram, pcb and muc status fro confirming that everything is OK.
2023-09-09 12:44 AM
Hello @SMazu.3
I'm not a PCB expert. I suggest you to close this post by choosing a best answer. And then create a new one including your new pcb request to have more audience and then you may have a good support.
Best regards.
II
2023-09-11 7:26 AM
I'm getting this output.
