2024-12-16 05:03 AM - last edited on 2024-12-16 05:12 AM by Andrew Neil
I am using the STM32WB55 microcontroller for my product. I want to connect more than one module to my Windows laptop. When I pair one module, it pairs correctly, but when I try to connect another module with the same firmware, it shows the message "Try to connect your device again" and does not connect. I have tried changing many things, but it is still not working. Where do I need to make changes so I can connect both devices with the same firmware to my laptop?
2025-01-14 05:25 AM
Hello @amit_ble
This depends on the tolerated number of connections on the central side (your PC). And not on the STM32WB side (that will be the peripheral).So, please check the capability of your BLE module (on the PC).
Best Regards.
STTwo-32
2025-01-14 05:25 AM
Hello @amit_ble
Best Regards.
STTwo-32
