2019-06-26 08:58 AM
Hi. I am trying to update my board using STM32WB Copro Wireless Binaries. But, I am getting following error:
I cannot download the image.
Can you please help me with this issue? I can flash the board but cannot use bluetooth functionality.
2019-06-26 11:18 PM
Hi
Your upgrade fails because the FUS binary can't be found. Maybe you could try to change the parameter for file path to something like: "c:\myfolder\stm32wb5x_FUS_fw.bin"
Regards Adrian
2019-06-26 11:18 PM
Hi
Regards Adrian
2019-06-27 01:41 AM
Thanks Adrian. It worked. I was under the impression that upgrade command will download this file over the air.
To all community members, these binary files are listed here: https://github.com/STMicroelectronics/STM32CubeWB/tree/master/Projects/STM32WB_Copro_Wireless_Binaries
2019-07-13 08:05 AM
I think for the 1 MB device the address given in the command line should ve 0x080cc000.
