Can't find the schematics of the STM32WB5MM-DK
A.D.
Edit:
It's always embarrassing when you ask a question and immediately afterwards you find what you where looking for...
Please ignore this question.
Original question:
I'm starting to work with the STM32WB5MM-DK, but I can't find the schematics. Are they not available yet?
For some first visual feedback I wanted to use the RGB LED, but the user manual of the DK says:
"In this configuration, GPIO_SELECT2 (PH1) is the chip select for this RGB device on SPI1.
The RGB LED is driven by the TLC59731 PWM LED driver from Texas Instruments."
Unfortunately theTLC59731 doesn't have a chip select. And the data protocol is not SPI, but some weird "EasySet" single wire interface.
So I would like to check the board schematics, to understand how the TLC chip is wired to the STM.
Imen.D
Hello @A.D.​
You can find here the STM32WB5MM Discovery Kit schematic.
Thanks for your contribution.
Imen
Imen
1 REPLY 1
Imen.D
Hello @A.D.​
Imen
Imen
