Board support package
Rituraj
I have a very generic question ,What happens if in an example for a different board . I just remove the BSP and instead add a BSP for a different board.
Pavel A.
Evangelist III
A generic answer to the generic question. When you replace or adapt a BSP from a different board you
1.Make it build without errors, find all missing parts etc.
2. Debug and validate that it works.
What happens next depends on success of these two steps.
4 REPLIES 4
Pavel A.
Evangelist III
To be even more generic:
"When you replace or adapt any firmware from a different board you ..."
@Andrew Neil Your sarcasm wasn't required here.
I'm sorry, it's not intended as sarcasm - it is a general principle.
