Bluetooth under windows 11 issue
‎2022-10-07 11:27 PM
Hi
this is not a specific Stm32WB question, but still relevant for any BLE development.
I am working on a STM32WB design. I wanted to see what happens when I have different Bluetooth chips on the host side. SO I bought a TP-LINK bluetooth USB dongle. As soon as I attached this USB dongle to my laptop, no usb isn working on my laptop anymore.
So now bluetooth is not working on my laptop anymore. I cant connect to my old Bluetooth loudspeaker and and and. My ble mouse is still working.
what I did so far for recovery:
- restart laptop
- remove alle the paired devices
- uninstall the device driver in device manager and restart
- try a different USB Bluetooth dongle.
Any further ideas?
STM32WB series
‎2022-10-08 03:41 PM
Remove the laptop battery, wait 10 minutes and try again.
Is your laptop still under warranty? If it has a CD/DVD drive, try to boot a Linux live CD and check the ports in Linux.
‎2024-04-26 04:31 AM
Thread is a little older but maybe it helps others.
It is tricky to add/remove devices connected to bluetooth-adapters which are currently unplugged e.g. if you switch from internal Bluetooth module (most often Intel I guess) to a USB dongle.
Go to device manager and enable "Show hidden devices". You should now be able to see Bluetooth devices connected to a bluetooth module currently not in use and remove/uninstall them to reconnect them afterwards. Maybe it helps to reconnect to Bluetooth devices used before.
Greetings
