BLE Communication between two STM32WB55 devices not working as expected.
li4
Device A (the client) cannot receive data from Device B (t
static SVCCTL_EvtAckStatus_t Event_Handler(void *Event)
  SVCCTL_EvtAckStatus_t return_value;
  hci_event_pckt *event_pckt;
  evt_blecore_aci *blecore_evt;
  P2P_Client_App_Notification_evt_t Notification;
  return_value = SVCCTL_EvtNotAck;
  event_pckt = (hci_event_pckt *)(((hci_uart_pckt*)Event)->data);
  switch(event_pckt->evt)
    case HCI_VENDOR_SPECIFIC_DEBUG_EVT_CODE:
      blecore_evt = (evt_blecore_aci*)event_pckt->data;
			APP_DBG_MSG("ECODE 0x%x\n", blecore_evt->ecode);
      switch(blecore_evt->ecode)
        case ACI_ATT_READ_BY_GROUP_TYPE_RESP_VSEVT_CODE:
          aci_att_read_by_group_type_resp_event_rp0 *pr = (void*)blecore_evt->data;
          uint8_t numServ, i, idx;
          uint16_t uuid, handle;
          uint8_t index;
          handle = pr->Connection_Handle;
          index = 0;
          while((index < BLE_CFG_CLT_MAX_NBR_CB) &&
                  (aP2PClientContext[index].state != APP_BLE_IDLE))
            APP_BLE_ConnStatus_t status;
            status = APP_BLE_Get_Client_Connection_Status(aP2PClientContext[index].connHandle);
            if((aP2PClientContext[index].state == APP_BLE_CONNECTED_CLIENT)&&
                    (status == APP_BLE_IDLE))
              /* Handle deconnected */
              aP2PClientContext[index].state = APP_BLE_IDLE;
              aP2PClientContext[index].connHandle = 0xFFFF;
              break;
            index++;
          if(index < BLE_CFG_CLT_MAX_NBR_CB)
            aP2PClientContext[index].connHandle= handle;
            numServ = (pr->Data_Length) / pr->Attribute_Data_Length;
            /* the event data will be
             * 2bytes start handle
             * 2bytes end handle
             * 2 or 16 bytes data
             * we are interested only if the UUID is 16 bit.
             * So check if the data length is 6
#if (UUID_128BIT_FORMAT==1)
          if (pr->Attribute_Data_Length == 20)
            idx = 16;
#else
          if (pr->Attribute_Data_Length == 6)
            idx = 4;
#endif
              for (i=0; i<numServ; i++)
                uuid = UNPACK_2_BYTE_PARAMETER(&pr->Attribute_Data_List[idx]);
                if(uuid == P2P_SERVICE_UUID)
#if(CFG_DEBUG_APP_TRACE != 0)
                  APP_DBG_MSG("-- GATT : P2P_SERVICE_UUID FOUND - connection handle 0x%x \n", aP2PClientContext[index].connHandle);
#endif
                aP2PClientContext[index].P2PServiceHandle = UNPACK_2_BYTE_PARAMETER(&pr->Attribute_Data_List[idx-16]);
                aP2PClientContext[index].P2PServiceEndHandle = UNPACK_2_BYTE_PARAMETER (&pr->Attribute_Data_List[idx-14]);
#else
                aP2PClientContext[index].P2PServiceHandle = UNPACK_2_BYTE_PARAMETER(&pr->Attribute_Data_List[idx-4]);
                aP2PClientContext[index].P2PServiceEndHandle = UNPACK_2_BYTE_PARAMETER (&pr->Attribute_Data_List[idx-2]);
#endif
                  aP2PClientContext[index].state = APP_BLE_DISCOVER_CHARACS ;
                idx += 6;
        break;
        case ACI_ATT_READ_BY_TYPE_RESP_VSEVT_CODE:
          aci_att_read_by_type_resp_event_rp0 *pr = (void*)blecore_evt->data;
          uint8_t idx;
           * 2 bytes start handle
           * 1 byte char properties
           * 2 bytes handle
          uint8_t index;
          index = 0;
                  (aP2PClientContext[index].connHandle != pr->Connection_Handle))
            index++;
            /* we are interested in only 16 bit UUIDs */
            idx = 17;
            if (pr->Handle_Value_Pair_Length == 21)
#else
              idx = 5;
            if (pr->Handle_Value_Pair_Length == 7)
#endif
              pr->Data_Length -= 1;
              while(pr->Data_Length > 0)
                uuid = UNPACK_2_BYTE_PARAMETER(&pr->Handle_Value_Pair_Data[idx]);
                /* store the characteristic handle not the attribute handle */
                handle = UNPACK_2_BYTE_PARAMETER(&pr->Handle_Value_Pair_Data[idx-14]);
#else
                handle = UNPACK_2_BYTE_PARAMETER(&pr->Handle_Value_Pair_Data[idx-2]);
#endif
                if(uuid == P2P_WRITE_CHAR_UUID)
                  APP_DBG_MSG("-- GATT : WRITE_UUID FOUND - connection handle 0x%x\n", aP2PClientContext[index].connHandle);
#endif
                  aP2PClientContext[index].state = APP_BLE_DISCOVER_WRITE_DESC;
                  aP2PClientContext[index].P2PWriteToServerCharHdle = handle;
                else if(uuid == P2P_NOTIFY_CHAR_UUID)
                  APP_DBG_MSG("-- GATT : NOTIFICATION_CHAR_UUID FOUND  - connection handle 0x%x\n", aP2PClientContext[index].connHandle);
#endif
                  aP2PClientContext[index].state = APP_BLE_DISCOVER_NOTIFICATION_CHAR_DESC;
                  aP2PClientContext[index].P2PNotificationCharHdle = handle;
                pr->Data_Length -= 21;
                idx += 21;
#else
                pr->Data_Length -= 7;
                idx += 7;
#endif
        break;
        case ACI_ATT_FIND_INFO_RESP_VSEVT_CODE:
          aci_att_find_info_resp_event_rp0 *pr = (void*)blecore_evt->data;
          uint8_t numDesc, idx, i;
           * event data will be of the format
           * 2 bytes handle
           * 2 bytes UUID
          uint8_t index;
          index = 0;
            index++;
            numDesc = (pr->Event_Data_Length) / 4;
            /* we are interested only in 16 bit UUIDs */
            idx = 0;
            if (pr->Format == UUID_TYPE_16)
              for (i=0; i<numDesc; i++)
                handle = UNPACK_2_BYTE_PARAMETER(&pr->Handle_UUID_Pair[idx]);
                uuid = UNPACK_2_BYTE_PARAMETER(&pr->Handle_UUID_Pair[idx+2]);
                if(uuid == CLIENT_CHAR_CONFIG_DESCRIPTOR_UUID)
                  APP_DBG_MSG("-- GATT : CLIENT_CHAR_CONFIG_DESCRIPTOR_UUID- connection handle 0x%x\n", aP2PClientContext[index].connHandle);
#endif
                  if( aP2PClientContext[index].state == APP_BLE_DISCOVER_NOTIFICATION_CHAR_DESC)
                    aP2PClientContext[index].P2PNotificationDescHandle = handle;
                    aP2PClientContext[index].state = APP_BLE_ENABLE_NOTIFICATION_DESC;
                idx += 4;
        break; /*ACI_ATT_FIND_INFO_RESP_VSEVT_CODE*/
        case ACI_GATT_NOTIFICATION_VSEVT_CODE:
          aci_gatt_notification_event_rp0 *pr = (void*)blecore_evt->data;
          uint8_t index;
          index = 0;
            index++;
            if ( (pr->Attribute_Handle == aP2PClientContext[index].P2PNotificationCharHdle) &&
                    (pr->Attribute_Value_Length == (2)) )
              Notification.P2P_Client_Evt_Opcode = P2P_NOTIFICATION_INFO_RECEIVED_EVT;
              Notification.DataTransfered.Length = pr->Attribute_Value_Length;
              Notification.DataTransfered.pPayload = &pr->Attribute_Value[0];
              Gatt_Notification(&Notification);
              /* INFORM APPLICATION BUTTON IS PUSHED BY END DEVICE */
        break;/* end ACI_GATT_NOTIFICATION_VSEVT_CODE */
        case ACI_GATT_PROC_COMPLETE_VSEVT_CODE:
          aci_gatt_proc_complete_event_rp0 *pr = (void*)blecore_evt->data;
          APP_DBG_MSG("-- GATT : ACI_GATT_PROC_COMPLETE_VSEVT_CODE \n");
          APP_DBG_MSG("\n");
#endif
          uint8_t index;
          index = 0;
            index++;
            UTIL_SEQ_SetTask( 1<<CFG_TASK_SEARCH_SERVICE_ID, CFG_SCH_PRIO_0);
        break; /*ACI_GATT_PROC_COMPLETE_VSEVT_CODE*/
        default:
          break;
    break; /* HCI_VENDOR_SPECIFIC_DEBUG_EVT_CODE */
    default:
      break;
  return(return_value);
}/* end BLE_CTRL_Event_Acknowledged_Status_t */
Serial port debug log :
ECODE 0xc0a
ECODE 0xc0a
-- GATT : P2P_SERVICE_UUID FOUND - connection handle 0x801
ECODE 0xc11
0 REPLIES 0
