Bluetooth Communication between two STM32WB55 not working
li4
Communication between two STM32WB55 devices via Bluetooth is not working as expected. Device A (the client) cannot receive data from Device B (t
static SVCCTL_EvtAckStatus_t Event_Handler(void *Event)
SVCCTL_EvtAckStatus_t return_value;
hci_event_pckt *event_pckt;
evt_blecore_aci *blecore_evt;
P2P_Client_App_Notification_evt_t Notification;
return_value = SVCCTL_EvtNotAck;
event_pckt = (hci_event_pckt *)(((hci_uart_pckt*)Event)->data);
switch(event_pckt->evt)
case HCI_VENDOR_SPECIFIC_DEBUG_EVT_CODE:
blecore_evt = (evt_blecore_aci*)event_pckt->data;
switch(blecore_evt->ecode)
case ACI_ATT_READ_BY_GROUP_TYPE_RESP_VSEVT_CODE:
aci_att_read_by_group_type_resp_event_rp0 *pr = (void*)blecore_evt->data;
uint8_t numServ, i, idx;
uint16_t uuid, handle;
uint8_t index;
handle = pr->Connection_Handle;
index = 0;
while((index < BLE_CFG_CLT_MAX_NBR_CB) &&
(aP2PClientContext[index].state != APP_BLE_IDLE))
APP_BLE_ConnStatus_t status;
status = APP_BLE_Get_Client_Connection_Status(aP2PClientContext[index].connHandle);
if((aP2PClientContext[index].state == APP_BLE_CONNECTED_CLIENT)&&
(status == APP_BLE_IDLE))
/* Handle deconnected */
aP2PClientContext[index].state = APP_BLE_IDLE;
aP2PClientContext[index].connHandle = 0xFFFF;
break;
index++;
if(index < BLE_CFG_CLT_MAX_NBR_CB)
aP2PClientContext[index].connHandle= handle;
numServ = (pr->Data_Length) / pr->Attribute_Data_Length;
/* the event data will be
* 2bytes start handle
* 2bytes end handle
* 2 or 16 bytes data
* we are interested only if the UUID is 16 bit.
* So check if the data length is 6
#if (UUID_128BIT_FORMAT==1)
if (pr->Attribute_Data_Length == 20)
idx = 16;
#else
if (pr->Attribute_Data_Length == 6)
idx = 4;
#endif
for (i=0; i<numServ; i++)
uuid = UNPACK_2_BYTE_PARAMETER(&pr->Attribute_Data_List[idx]);
if(uuid == P2P_SERVICE_UUID)
#if(CFG_DEBUG_APP_TRACE != 0)
APP_DBG_MSG("-- GATT : P2P_SERVICE_UUID FOUND - connection handle 0x%x \n", aP2PClientContext[index].connHandle);
#endif
aP2PClientContext[index].P2PServiceHandle = UNPACK_2_BYTE_PARAMETER(&pr->Attribute_Data_List[idx-16]);
aP2PClientContext[index].P2PServiceEndHandle = UNPACK_2_BYTE_PARAMETER (&pr->Attribute_Data_List[idx-14]);
#else
aP2PClientContext[index].P2PServiceHandle = UNPACK_2_BYTE_PARAMETER(&pr->Attribute_Data_List[idx-4]);
aP2PClientContext[index].P2PServiceEndHandle = UNPACK_2_BYTE_PARAMETER (&pr->Attribute_Data_List[idx-2]);
#endif
aP2PClientContext[index].state = APP_BLE_DISCOVER_CHARACS ;
idx += 6;
break;
case ACI_ATT_READ_BY_TYPE_RESP_VSEVT_CODE:
aci_att_read_by_type_resp_event_rp0 *pr = (void*)blecore_evt->data;
uint8_t idx;
* 2 bytes start handle
* 1 byte char properties
* 2 bytes handle
uint8_t index;
index = 0;
(aP2PClientContext[index].connHandle != pr->Connection_Handle))
index++;
/* we are interested in only 16 bit UUIDs */
idx = 17;
if (pr->Handle_Value_Pair_Length == 21)
#else
idx = 5;
if (pr->Handle_Value_Pair_Length == 7)
#endif
pr->Data_Length -= 1;
while(pr->Data_Length > 0)
uuid = UNPACK_2_BYTE_PARAMETER(&pr->Handle_Value_Pair_Data[idx]);
/* store the characteristic handle not the attribute handle */
handle = UNPACK_2_BYTE_PARAMETER(&pr->Handle_Value_Pair_Data[idx-14]);
#else
handle = UNPACK_2_BYTE_PARAMETER(&pr->Handle_Value_Pair_Data[idx-2]);
#endif
if(uuid == P2P_WRITE_CHAR_UUID)
APP_DBG_MSG("-- GATT : WRITE_UUID FOUND - connection handle 0x%x\n", aP2PClientContext[index].connHandle);
#endif
aP2PClientContext[index].state = APP_BLE_DISCOVER_WRITE_DESC;
aP2PClientContext[index].P2PWriteToServerCharHdle = handle;
else if(uuid == P2P_NOTIFY_CHAR_UUID)
APP_DBG_MSG("-- GATT : NOTIFICATION_CHAR_UUID FOUND - connection handle 0x%x\n", aP2PClientContext[index].connHandle);
#endif
aP2PClientContext[index].state = APP_BLE_DISCOVER_NOTIFICATION_CHAR_DESC;
aP2PClientContext[index].P2PNotificationCharHdle = handle;
pr->Data_Length -= 21;
idx += 21;
#else
pr->Data_Length -= 7;
idx += 7;
#endif
break;
case ACI_ATT_FIND_INFO_RESP_VSEVT_CODE:
aci_att_find_info_resp_event_rp0 *pr = (void*)blecore_evt->data;
uint8_t numDesc, idx, i;
* event data will be of the format
* 2 bytes handle
* 2 bytes UUID
uint8_t index;
index = 0;
index++;
numDesc = (pr->Event_Data_Length) / 4;
/* we are interested only in 16 bit UUIDs */
idx = 0;
if (pr->Format == UUID_TYPE_16)
for (i=0; i<numDesc; i++)
handle = UNPACK_2_BYTE_PARAMETER(&pr->Handle_UUID_Pair[idx]);
uuid = UNPACK_2_BYTE_PARAMETER(&pr->Handle_UUID_Pair[idx+2]);
if(uuid == CLIENT_CHAR_CONFIG_DESCRIPTOR_UUID)
APP_DBG_MSG("-- GATT : CLIENT_CHAR_CONFIG_DESCRIPTOR_UUID- connection handle 0x%x\n", aP2PClientContext[index].connHandle);
#endif
if( aP2PClientContext[index].state == APP_BLE_DISCOVER_NOTIFICATION_CHAR_DESC)
aP2PClientContext[index].P2PNotificationDescHandle = handle;
aP2PClientContext[index].state = APP_BLE_ENABLE_NOTIFICATION_DESC;
idx += 4;
break; /*ACI_ATT_FIND_INFO_RESP_VSEVT_CODE*/
case ACI_GATT_NOTIFICATION_VSEVT_CODE:
aci_gatt_notification_event_rp0 *pr = (void*)blecore_evt->data;
uint8_t index;
index = 0;
index++;
if ( (pr->Attribute_Handle == aP2PClientContext[index].P2PNotificationCharHdle) &&
(pr->Attribute_Value_Length == (2)) )
Notification.P2P_Client_Evt_Opcode = P2P_NOTIFICATION_INFO_RECEIVED_EVT;
Notification.DataTransfered.Length = pr->Attribute_Value_Length;
Notification.DataTransfered.pPayload = &pr->Attribute_Value[0];
Gatt_Notification(&Notification);
/* INFORM APPLICATION BUTTON IS PUSHED BY END DEVICE */
break;/* end ACI_GATT_NOTIFICATION_VSEVT_CODE */
case ACI_GATT_PROC_COMPLETE_VSEVT_CODE:
aci_gatt_proc_complete_event_rp0 *pr = (void*)blecore_evt->data;
APP_DBG_MSG("-- GATT : ACI_GATT_PROC_COMPLETE_VSEVT_CODE \n");
APP_DBG_MSG("\n");
#endif
uint8_t index;
index = 0;
index++;
UTIL_SEQ_SetTask( 1<<CFG_TASK_SEARCH_SERVICE_ID, CFG_SCH_PRIO_0);
break; /*ACI_GATT_PROC_COMPLETE_VSEVT_CODE*/
default:
break;
break; /* HCI_VENDOR_SPECIFIC_DEBUG_EVT_CODE */
default:
break;
return(return_value);
}/* end BLE_CTRL_Event_Acknowledged_Status_t */
7 REPLIES 7
Andrew Neil
welcome to the forum.
Please give details of your setup, tools, what debugging you've tried, etc:
See: How to write your question to maximize your chances to find a solution
Also: How to insert source code
li4
/* USER CODE BEGIN APP_BLE_Init_2 */
UTIL_SEQ_SetTask(1 << CFG_TASK_START_SCAN_ID, CFG_SCH_PRIO_0);
/* USER CODE END APP_BLE_Init_2 */
case AD_TYPE_MANUFACTURER_SPECIFIC_DATA: /* Manufacturer Specific */
/* USER CODE BEGIN AD_TYPE_MANUFACTURER_SPECIFIC_DATA */
/* USER CODE END AD_TYPE_MANUFACTURER_SPECIFIC_DATA */
if (adlength >= 7 && adv_report_data[k + 2] == 0x01)
{ /* ST VERSION ID 01 */
APP_DBG_MSG("--- ST MANUFACTURER ID --- \n\r");
// switch (adv_report_data[k + 3])
// { /* Demo ID */
// case CFG_DEV_ID_P2P_SERVER1: /* End Device 1 */
APP_DBG_MSG("-- SERVER DETECTED -- VIA MAN ID\n\r");
BleApplicationContext.DeviceServerFound = 0x01;
SERVER_REMOTE_ADDR_TYPE = 0x00;
SERVER_REMOTE_BDADDR[0] = 0x14;
SERVER_REMOTE_BDADDR[1] = 0x24;
SERVER_REMOTE_BDADDR[2] = 0x00;
SERVER_REMOTE_BDADDR[3] = 0xE1;
SERVER_REMOTE_BDADDR[4] = 0x80;
SERVER_REMOTE_BDADDR[5] = 0x02;
// break;
// default:
// break;
break;
li4
li4_4-1742788973099.pngli4_5-1742788986325.pngli4_6-1742788999409.pngli4_7-1742789011906.pngli4_8-1742789022157.png
** CREATE CONNECTION TO SERVER **
** CONNECTION COMPLETE EVENT WITH SERVER
** GATT SERVICES & CHARACTERISTICS DISCOVERY
* GATT : Start Searching Primary Services
ECODE: 0xc0a
ECODE: 0xc0a
-- GATT : P2P_SERVICE_UUID FOUND - connection handle 0x801
aP2PClientContext[index].P2PServiceHandle 0xc
aP2PClientContext[index].P2PServiceEndHandle 0x11
ECODE: 0xc11
为什么在以下日志之后 ECODE 更改为 0xc11:ECODE: 0xc0a, ECODE: 0xc0a, -- GATT: P2P_SERVICE_UUID FOUND - 连接句柄 0x801, aP2PClientContext[index].P2PServiceHandle 0xc,aP2PClientContext[index].P2PServiceEndHandle 0x11?
Google translate:
Why does ECODE change to 0xc11 after the following logs: ECODE: 0xc0a, ECODE: 0xc0a, -- GATT: P2P_SERVICE_UUID FOUND - Connection handle 0x801, aP2PClientContext[index].P2PServiceHandle 0xc, aP2PClientContext[index].P2PServiceEndHandle 0x11?
Again, please see How to insert source code.
#if (OOB_DEMO == 0)
   * Start scanning
#endif
  return;static void Connect_Request(void)
  /* USER CODE BEGIN Connect_Request_1 */
	uint8_t paddr[]={0x14,0x24,0x00,0xE1,0x80,0x02};
  /* USER CODE END Connect_Request_1 */
  tBleStatus result;
  APP_DBG_MSG("\r\n\r** CREATE CONNECTION TO SERVER **  \r\n\r");
  if (BleApplicationContext.Device_Connection_Status != APP_BLE_CONNECTED_CLIENT)
    result = aci_gap_create_connection(SCAN_P,
                                       SCAN_L,
                                       SERVER_REMOTE_ADDR_TYPE, paddr,
                                       CFG_BLE_ADDRESS_TYPE,
                                       CONN_P1,
                                       CONN_P2,
                                       0,
                                       SUPERV_TIMEOUT,
                                       CONN_L1,
                                       CONN_L2);
    if (result == BLE_STATUS_SUCCESS)
      /* USER CODE BEGIN BLE_CONNECT_SUCCESS */
      /* USER CODE END BLE_CONNECT_SUCCESS */
      BleApplicationContext.Device_Connection_Status = APP_BLE_LP_CONNECTING;
    else
      /* USER CODE BEGIN BLE_CONNECT_FAILED */
      /* USER CODE END BLE_CONNECT_FAILED */
      BleApplicationContext.Device_Connection_Status = APP_BLE_IDLE;
  /* USER CODE BEGIN Connect_Request_2 */
  /* USER CODE END Connect_Request_2 */
  return;
li4
		  APP_DBG_MSG("ECODE 0x%x \n", blecore_evt->ecode);
          uint8_t index;
          index = 0;
              break;
            index++;
             * 2bytes end handle
            idx = 16;
#else
            idx = 4;
#endif
#endif
#else
#endif
                  APP_DBG_MSG("aP2PClientContext[index].P2PServiceHandle 0x%x \n", aP2PClientContext[index].P2PServiceHandle);
									APP_DBG_MSG("aP2PClientContext[index].P2PServiceEndHandle 0x%x \n", aP2PClientContext[index].P2PServiceEndHandle);
                  aP2PClientContext[index].state = APP_BLE_DISCOVER_CHARACS;
               idx += 6;
        break;
          uint8_t idx;
           * 2 bytes handle
          uint8_t index;
          index = 0;
            index++;
            idx = 17;
#else
              idx = 5;
#endif
#else
#endif
#endif
#endif
                idx += 21;
#else
                idx += 7;
#endif
        break;
           * 2 bytes handle
           * 2 bytes UUID
          uint8_t index;
          index = 0;
            index++;
            idx = 0;
#endif
                idx += 4;
          uint8_t index;
          index = 0;
            index++;
//					/*GAP中央设备启动发现所有服务特征的
//					流程:conn_handle是hci_le_advertising_report_event()事件回调返回的连接句柄 */
//					if(aci_gatt_disc_all_char_of_service(aP2PClientContext[index].connHandle, aP2PClientContext[index].P2PServiceHandle,/* Servicehandle */ aP2PClientContext[index].P2PServiceEndHandle/* 结束组句柄 */
//							) != BLE_STATUS_SUCCESS)
//					 APP_DBG_MSG("Failure.\n");
          APP_DBG_MSG("\n");
#endif
          uint8_t index;
          index = 0;
            index++;
        default:
          break;
    default:
      break;
