B-L072Z-LRWAN1 LoRa®Discovery kit using PB8 and PB9 IC2 with a display. Does not function properly
Developing with B-L072Z-LRWAN1 LoRa®Discovery kit with sensor board and GNSS Teseo.
I added an OLED ssd1306 and connected it on IC2 PB8 PB9. I can send commands but when I send data I very often get a display hang. How should I handle PB8 PB9? Should this be terminated? Is it a jumper to set on any of the 3 boards?
