Audio example in Nucleo-WBA55CG
Pallavi
Hi @STTwo-32  @TDK @KDJEM.1 @Issamos @Remy ISSALYS ,
I have started using Nucleo-WBA55CG for BLE Audio and realized STM32Cube_FW_WBA_V1.3.0 does not contain any audio code for the board. But STM32WBA55CG- DK1 has the ble audio snippet code.
Can I use the nucleo board to implement the audio examples since the microcontroller is same?
Thank You in advance.
STTwo-32
Hello @Pallavi
This example should be able to run on all STM32WBA55xx. But it has HW depends that are not implemented on the  Nucleo Board Specially the Audio Codec part:
Best Regards.
STTwo-32
6 REPLIES 6
STTwo-32
Hello @Pallavi
Best Regards.
STTwo-32
Hi @STTwo-32
Ok.
So do I have to connect a codec separately? Or what other circuit has to be interfaced on Nucleo to get the audio working?
Thank you for the reply!
Hi @STTwo-32
So, does this mean, to be able to implement the audio example, DK board is a necessity?
Can you please confrim.
Thank you !
If you are not going to add the external features mentioned above, you should use the DK boards to run those examples.
Best Regards.
STTwo-32
OK
Thank you so much
Can I use MAX98357 I2S breakout board and Adafruit I2S MEMS microphone to complete the circuit ?
@STTwo-32
