Are there any examples in I-CUBE-LRWAN SDK with .ioc STM32CUBEMX file?
milanvujovic
The reason I'm looking for it is because I was able to run SubGHz_Phy successfully but I'm unable to enable the I2C or GPIOs at all.
The board I'm using: Murata Type 1SJ
Best Regards.
Milan
5 REPLIES 5
Sara BEN HADJ YAHYA
Hi @milanvujovic​ ,
Could you please share your .ioc file and specify the STM32CubeMX version?
Thanks,
Sara.
OP *wants* examples as .IOC files​, assume latest revisions of tools.
@Community member​ Exactly, I'm looking for an example with .IOC file.
Sara BEN HADJ YAHYA
Hi @milanvujovic​ ,
I apologize for the misunderstanding.
There are no examples in I-CUBE-LRWAN, with an .ioc file at the moment.
However, I will suggest your request internally and I'll keep you posted with the updates.
Thanks,
Sara.
Hi @Sara BEN HADJ YAHYA​
Any updates for this request?
