Why is there so little training and examples on TouchGfx !!!!
JHERI
Senior
Hi Guys
How on earth does ST expect anyone to use, learn and embrace their products when there seem to be so little help , videos training??
TouchGFX is appalling for step by step examples, YES it's free, but no value to engineers if you have no idea or can't understand Toucgfx
I have been days traying to create an event  from a custom container with a toggle switch
under the container I have created an event for a toggle button
I have called the container panel which holds the toggle button and event
under generated gui I see the generated event handler
I then want to copy that event handler in to panel.cpp and create a new event for a custom container
The compiler just errors every time ????? I ready to lunch the PC
There must be a better easier way than touch GFX, im sure its great if you know what on earth you are doing
14 REPLIES 14
JHERI
Senior
this is the generated code
when i try to add this to add this to panel.cpp     (the custom container, just compiler errors ???
void PanelBase::buttonCallbackHandler(const touchgfx::AbstractButton& src)
if (&src== &ch1_tog)
//ev
//When ch1_tog clicked call virtual function
//Call ev
ev();
if (&src== &ch8_tog)
//JIMJIM
//When ch8_tog clicked call virtual function
//Call JIMJIM
JIMJIM();
JHERI
Senior
if I only try one event like below....
//ev
//Call ev
ev();
i still get errors ???
15:03:55 **** Incremental Build of configuration Debug for project Riverdi_70STM32H7_CM7 ****
make -j8 all
arm-none-eabi-g++ "C:/TouchGFXProjects/Train/CM7/TouchGFX/gui/src/containers/Panel.cpp" -mcpu=cortex-m7 -std=gnu++14 -g3 -DDEBUG -DCORE_CM7 -DUSE_HAL_DRIVER -DSTM32H747xx -c -I../../../CM7/Core/Inc -I../../../CM7/FATFS/Target -I../../../CM7/FATFS/App -I../../../CM7/TouchGFX/App -I../../../CM7/TouchGFX/target/generated -I../../../CM7/TouchGFX/target -I../../../Drivers/STM32H7xx_HAL_Driver/Inc -I../../../Drivers/STM32H7xx_HAL_Driver/Inc/Legacy -I../../../Utilities/JPEG -I../../../Middlewares/Third_Party/FatFs/src -I../../../Middlewares/Third_Party/FreeRTOS/Source/include -I../../../Middlewares/Third_Party/FreeRTOS/Source/CMSIS_RTOS_V2 -I../../../Middlewares/Third_Party/FreeRTOS/Source/portable/GCC/ARM_CM4F -I../../../Drivers/CMSIS/Device/ST/STM32H7xx/Include -I../../../Drivers/CMSIS/Include -I../../CM7/../../CM7/Middlewares/ST/touchgfx/framework/include -I../../CM7/../../CM7/TouchGFX/generated/fonts/include -I../../CM7/../../CM7/TouchGFX/generated/gui_generated/include -I../../CM7/../../CM7/TouchGFX/generated/images/include -I../../CM7/../../CM7/TouchGFX/generated/texts/include -I../../CM7/../../CM7/TouchGFX/generated/videos/include -I../../CM7/../../CM7/TouchGFX/gui/include -I../../../CM7/USB_HOST/App -I../../../CM7/USB_HOST/Target -I../../../Middlewares/ST/STM32_USB_Host_Library/Core/Inc -I../../../Middlewares/ST/STM32_USB_Host_Library/Class/MSC/Inc -O0 -ffunction-sections -fdata-sections -fno-exceptions -fno-rtti -fno-use-cxa-atexit -Wall -femit-class-debug-always -fstack-usage -fcyclomatic-complexity -MMD -MP -MF"Application/User/gui/Panel.d" -MT"Application/User/gui/Panel.o" --specs=nano.specs -mfpu=fpv5-d16 -mfloat-abi=hard -mthumb -o "Application/User/gui/Panel.o"
arm-none-eabi-g++ -o "Riverdi_70STM32H7_CM7.elf" @"objects.list" -l:libtouchgfx-float-abi-hard.a -mcpu=cortex-m7 -T"C:\TouchGFXProjects\Train\STM32CubeIDE\CM7\STM32H747XIHX_FLASH.ld" --specs=nosys.specs -Wl,-Map="Riverdi_70STM32H7_CM7.map" -Wl,--gc-sections -static -L../../CM7/../../CM7/Middlewares/ST/touchgfx/lib/core/cortex_m7/gcc -LC:/TouchGFXProjects/70STM32H7_v4_Copy/CM7/Middlewares/ST/touchgfx/lib/core/cortex_m7/gcc -LE:/TouchGFX/4.22.0/designer/Riverdi_70STM32H7/CM7/Middlewares/ST/touchgfx/lib/core/cortex_m7/gcc -LC:/TouchGFXProjects/MyApplication_56/CM7/Middlewares/ST/touchgfx/lib/core/cortex_m7/gcc -LC:/TouchGFXProjects/Train/CM7/Middlewares/ST/touchgfx/lib/core/cortex_m7/gcc --specs=nano.specs -mfpu=fpv5-d16 -mfloat-abi=hard -mthumb -Wl,--start-group -lc -lm -lstdc++ -lsupc++ -Wl,--end-group
C:/ST/STM32CubeIDE_1.13.0/STM32CubeIDE/plugins/com.st.stm32cube.ide.mcu.externaltools.gnu-tools-for-stm32.11.3.rel1.win32_1.1.0.202305231506/tools/bin/../lib/gcc/arm-none-eabi/11.3.1/../../../../arm-none-eabi/bin/ld.exe: ./Application/User/gui/Panel.o: in function `PanelBase::buttonCallbackHandler(touchgfx::AbstractButton const&)':
C:/TouchGFXProjects/Train/CM7/TouchGFX/gui/src/containers/Panel.cpp:22: multiple definition of `PanelBase::buttonCallbackHandler(touchgfx::AbstractButton const&)'; ./Application/User/generated/PanelBase.o:C:/TouchGFXProjects/Train/CM7/TouchGFX/generated/gui_generated/src/containers/PanelBase.cpp:296: first defined here
collect2.exe: error: ld returned 1 exit status
make[1]: *** [makefile:100: Riverdi_70STM32H7_CM7.elf] Error 1
make: *** [makefile:93: all] Error 2
"make -j8 all" terminated with exit code 2. Build might be incomplete.
15:04:00 Build Failed. 4 errors, 0 warnings. (took 5s.186ms)
JHERI
Senior
from ../../CM7/../../CM7/TouchGFX/gui/include/gui/output_zone1_screen/OUTPUT_ZONE1View.hpp:4,
from C:/TouchGFXProjects/Train/CM7/TouchGFX/gui/src/output_zone1_screen/OUTPUT_ZONE1View.cpp:1:
../../CM7/../../CM7/TouchGFX/gui/include/gui/containers/Panel.hpp:16:18: error: cannot declare member function 'PanelBase::buttonCallbackHandler' within 'Panel'
16 | virtual void PanelBase::buttonCallbackHandler(const touchgfx::AbstractButton& src);
In file included from ../../CM7/../../CM7/TouchGFX/generated/gui_generated/include/gui_generated/output_zone1_screen/OUTPUT_ZONE1ViewBase.hpp:12,
from C:/TouchGFXProjects/Train/CM7/TouchGFX/gui/src/output_zone1_screen/OUTPUT_ZONE1Presenter.cpp:1:
In file included from C:/TouchGFXProjects/Train/CM7/TouchGFX/gui/src/containers/Panel.cpp:1:
make[1]: *** [Application/User/gui/subdir.mk:47: Application/User/gui/OUTPUT_ZONE1View.o] Error 1
make[1]: *** Waiting for unfinished jobs....
make[1]: *** [Application/User/gui/subdir.mk:49: Application/User/gui/Panel.o] Error 1
make[1]: *** [Application/User/gui/subdir.mk:45: Application/User/gui/OUTPUT_ZONE1Presenter.o] Error 1
from C:/TouchGFXProjects/Train/CM7/TouchGFX/generated/gui_generated/src/output_zone1_screen/OUTPUT_ZONE1ViewBase.cpp:4:
from ../../CM7/../../CM7/TouchGFX/generated/gui_generated/include/gui_generated/common/FrontendHeapBase.hpp:15,
from ../../CM7/../../CM7/TouchGFX/gui/include/gui/common/FrontendHeap.hpp:4,
from C:/TouchGFXProjects/Train/CM7/TouchGFX/generated/gui_generated/src/common/FrontendApplicationBase.cpp:6:
make[1]: *** [Application/User/generated/subdir.mk:163: Application/User/generated/OUTPUT_ZONE1ViewBase.o] Error 1
make[1]: *** [Application/User/generated/subdir.mk:145: Application/User/generated/FrontendApplicationBase.o] Error 1
from C:/TouchGFXProjects/Train/CM7/TouchGFX/target/generated/TouchGFXConfiguration.cpp:21:
from C:/TouchGFXProjects/Train/CM7/TouchGFX/target/generated/TouchGFXGeneratedHAL.cpp:21:
make[1]: *** [Application/User/TouchGFX/target/generated/subdir.mk:44: Application/User/TouchGFX/target/generated/TouchGFXConfiguration.o] Error 1
make[1]: *** [Application/User/TouchGFX/target/generated/subdir.mk:46: Application/User/TouchGFX/target/generated/TouchGFXGeneratedHAL.o] Error 1
15:56:26 Build Failed. 16 errors, 0 warnings. (took 4s.17ms)
MM..1
Chief II
You know what is C++ ?
JHERI
Senior
I normally program in C
I understand classes and object orientated code,
just have no idea how to used touchgrfx ??? there is so little basic easy to understand examples
JHERI
Senior
MM..1
Chief II
Then why you place PanelBase into other class and ask why compiler say error.?
I agree learn TGFX is not easy. My tip is half year.
I disagree, examples is in designer , but in new version is more complicated to open.
JHERI
Senior
this is the code touchGfx generated ???
but there needs to be good documentation and examples examples examples
