Where is BMPFileLoader?
‎2019-03-24 11:35 PM
I didn't find “dynamic_bitmap_example“ in TouchGFX
- Labels:
TouchGFX
‎2019-03-28 3:25 PM
Hi @JaHnu​
A Dynamic Bitmap in TouchGFX is not necessarily just loading a BMP, dynamically. It means that you can modify a piece of memory at runtime and treat it as a Bitmap in TouchGFX. But, now that we're on the subject, you're right that the dynamic_bitmap_example from TouchGFX 4.8.0 has not made its way into the designer yet.
I've attached it here (based on 4.8.0).
/Martin
‎2019-03-28 3:25 PM
Hi @JaHnu​
/Martin
‎2019-03-28 6:43 PM
Thank you Martin KJELDSEN
‎2019-03-29 12:27 AM
You're welcome!
‎2019-04-04 10:57 AM
Missing lot of files.
‎2019-04-08 12:38 AM
This example is not maintained - I grabbed it from an old release. It should definitely be made into a UI template.
Are you able to get some inspiration from it?
