Where is the BMPFileLoader class?
LMC
where could i find ​the the BMPFileLoader class  menthioned in website ( https://touchgfx.zendesk.com/hc/en-us/articles/207460605-Dynamic-Bitmaps-Load-images-at-runtime)
it says,"The BMPFileLoader class used in the example can be found in the "dynamic_bitmap_example" provided with TouchGFX."
where is the example?how  to download?
Martin KJELDSEN
Chief III
Hi @LMC​,
The dynamic_bitmap_example was moved out of TouchGFX. Allow me to attach the files you're looking for,
8 REPLIES 8
Martin KJELDSEN
Chief III
Hi @LMC​,
​Thank you very much!
You're welcome. I know the example is missing and as soon as we can prioritize it we'll add more of the "old" examples that haven't been "designerfied" yet.
/Martin
Okay, i'm not really sure i understand the underlying issue. Can you exemplify with screenshots and code?
/Martin
Here's the entire dynamic bitmap application as it was in 4.8.0
I have downloaded the application, and will try to read the code. Thanks.​
Okay, let me know how you do.
