Using Custom Fonts in TouchGFX
‎2019-01-03 10:23 PM
Is it possible to use custom fonts other than True type fonts listed in Touchgfx Designer. Thanks
TouchGFX
‎2019-01-03 11:56 PM
Just dump it inside your assets/fonts/ folder and it should be picked up by the designer (After restart).
‎2019-01-03 11:48 PM
@PBU​, what kind of fonts do you have in mind? Formats we support are :
- TrueType (.ttf)
- OpenType (.otf)
- Glyph Bitmap Distribution format (.bdf)
‎2019-01-03 11:52 PM
I want to use TrueType Font (.ttf).
How to add custom true type font in touchGFX Designer?
‎2019-01-04 1:12 AM
Hi Martin,
Thanks. It Worked.
‎2022-07-22 7:17 AM
@Martin KJELDSEN​
Not all custom fonts appear to work.
See this post:
Is there anything you can tell me about a custom font that will prohibit it from working in the Designer?
