TuchGFX - STM32F412G-DISCO Scrollist items get from qspi flash
SKara.6
Hello everyone. I just met Touch Gfx and I am a student.
I want to display a list I saved in the first sector of qspi flash in the scrollist
but I could not reach a kind of result
I kept the first 2mb of the flash to myself
/* Memories definition */
MEMORY
  RAM    (xrw)    : ORIGIN = 0x20000000,   LENGTH = 256K
  FLASH    (rx)    : ORIGIN = 0x8000000,   LENGTH = 1024K
  QSPI     (r)     : ORIGIN = 0x90200000,  LENGTH = 14M
// *****  readTable.h ****
class readTable
public:
	void kategorisayisi ();  //	reading and extracting data from flash
	char * RitimIsmiGonder(int no); //for ScrollRitimUpdateItem call
private:
	char * ritimListesi[121];   // The array I want to send to the scrollist widget
I do reading, extracting and sending in a class called readTable.
// readTable.cpp
uint16_t sizem = 1000;
volatile char  *externalFlash =( char * ) 0x90000000;
 char  data[1000];
 char delim[] = "\r\n";
	void readTable::kategorisayisi()
		for(uint16_t i = 0; i < sizem; i++)
			data[i] = externalFlash[i];        //dump form extFlash
		char *ptr = strtok(data, delim);   // sorting process
		 	for(int i=0;i<121;i++)
		 		ritimListesi[i]=ptr;            //  transfer fragmented data to array
		 		ptr = strtok(NULL, delim);
	char *  readTable::RitimIsmiGonder(int no)
		return ritimListesi[no];       //Array element returning for ScrollRitimUpdateItem call
// **** scrollist CustomContainer *****
#include <gui/containers/RitimIsimleriLCont.hpp>
#include "readTable.hpp"
RitimIsimleriLCont::RitimIsimleriLCont()
readTable rt;
void RitimIsimleriLCont::initialize()
    RitimIsimleriLContBase::initialize();
void RitimIsimleriLCont::setNumber(uint8_t no)
		Unicode::strncpy(RitimlerBuffer ,( const char *)t.RitimIsmiGonder(no) ,10 ); // Calling my list array element
After all, I can't see anything in the scrollist (sometimes '?' Characters are seen)
I can follow it to a point while debugging the program.
 but after a while I lose all values.
Where am I making a mistake? An eye to see from the outside will help me a lot.
Thank you in advance...
MM..1
Chief II
I see little complicated solution and scroll code you dont show , when you have any.
Scrollist need this method in view code
void Screen3View::scrollList1UpdateItem(MenuItem &item, int16_t itemIndex) {
and in this method you can directly read from qflash instead your class...
scrollList1.setNumberOfItems(sizeof(UI_Menu_Items_A));
In setup code for screen you only need set number of items.
4 REPLIES 4
MM..1
Chief II
Thank you very much for your reply.
 I have a method like.
void AnaSayfaView::ScrollRitimUpdateItem(RitimIsimleriLCont& item, int16_t itemIndex)
	 	 item.setNumber(itemIndex);
I will look at the subject.
Since I don't know how to extract data directly from q flash, I used such a method =)
OK you can use class setNumber, but strncpy do nothing with your gui.
You need after this call customcontainer element text invalidate.
textArea1.setWildcard(textArea1Buffer);
textArea1.invalidate();
textArea1.resizeToCurrentTextWithAlignment();
I guess my problem is that this function doesn't send any value.
where return ritimListesi [no]; there is a problem.
