TouchGFX
‎2024-06-05 11:06 PM
Hi Team,
I have a requirement to create an elevator animation based on user input.
I have a 3D image representing a single floor, and I am using it in a container to create a scroll list for multiple floors. However, because of the 3D image, there is a gap between the floors, which is causing issues.
Please find the attached images showing the actual output and the desired output. How can I manage this gap effectively?
Thank you.
TouchGFX Designer
‎2024-06-05 11:32 PM
Transparency ...
‎2024-06-06 12:18 AM
I am Using Transparent Image for Box
But it reflected on main page as attached file
‎2024-06-06 12:58 AM - edited ‎2024-06-06 1:14 AM
It looks like a vector image with a few straight and a few diagonal lines. You can use inkscape to draw the vector image and then export it as svg or as png. So a single image.
Another solution is to use the line object in TouchGFX. The floors are 3 vertical lines in total and 2 diagonal lines per floor (+ 4 extra for top floor).
Click "Accept as Solution" if a reply solved your problem. If no solution was posted please answer with your own.
‎2024-06-06 2:54 AM - edited ‎2024-06-06 2:55 AM
Hello @APate.18,
You cant put negative margin in Designer, a simple solution is to directly edit the project file (myproject.touchgfx).
The steps:
1) Put margin to a value above 0 (Or add manually in the project file "itemMargin" in component->scrolllist)
2) Generate the project
3) Edit "ItemMargin" in the project file
4) Go back to designer, accept to reload.
tweak the margin value with steps 3-4 until you find the one you need.
I hope it helps,
‎2024-06-06 4:50 AM
Is it possible using custom container.?
‎2024-06-06 7:26 AM - edited ‎2024-06-06 8:13 AM
My tip start with tiled image + Special image on top + cabin image ...
read Tiled Image | TouchGFX Documentation
