2024-12-04 01:16 PM
Hi there,
I was trying to use the TouchGFX Designer Template for the H563ZI dev board with the RVA35HI display. However I noticed that I have REV1.0 of the display whereas the template that is generated is for REV1.1.
I tried configuring the pin connections through the .ioc files by referring to respective version datasheet but so far no luck. It would of great help if there was any way in which I can be given the template for the display version that I've got.
Any help would be really appreciated.
Cheers
2024-12-15 06:02 PM
Thank you so much for your help @mathiasmarkussen @GaetanGodart
Got the V1.1 and it works. Saved me all the effort :)
Cheers,
Charan
