TouchGFX generation in STM32 CubeMX
magicmarmot
I have the library installed, the application selected, and the selection under Additional Software X-CUBE-TOUCHGFX... selected and enabled.
However, when I hit Generate Code, none of the TouchGFX folders are created, and the build fails with missing files all related to TouchGFX. How do I get CubeMX to generate these files?
12 REPLIES 12
Karan 123
Which Hardware board you are using ?
Did for install X-CUBE-TouchGFX 4.13.0 ?
If Installed have you select in STM32CubeMX?
Additional Software
   -> STMicroelectronics-X-CUBE-TouchGFX 4.13.0
  -> Graphic Application -> Select
I am attaching as notepad How_to_STM32F746_Discovery_TouchGFX_4.13.0_STM32CubeIDE_1.3.0 not for (STM32 Cube MX).
Hope this Helps..
Karan
Karan
magicmarmot
Hi Karan,
This is a custom board for a client.
I'm following through your instructions, but I'm stuck on step 16. AT step 15 (Click "Generate Code") , there is no TouchGFX code generated. If I create a new blank TouchGFX simulator project, there is no "Test Hardware IDE" icon that I can find.
Sorry, I did find it in the Src folder of the project, but I still don't see a ""Test Hardware IDE" icon.
Your Project name may be Different ..
Please check below:
Karan
magicmarmot
Ah-- you're using the STM32CubeIDE. We're using Keil uVision.
Karan 123
But I think steps should be almost same ..
Did you able to proceed from Step 15 ?
I'm installing the Cube IDE right now.
Karan 123
Hope you get success ..
Right ?
Karan
Yes, mostly, thank you. I was able to create a TouchGFX application that runs (more or less) on the target hardware. We still have some issues, but I think we're down to a smaller set of problems. 🙂
