TouchGFX GCC C++ exceptions handling
JJame.1
related to the post https://community.st.com/t5/stm32-mcus-touchgfx-and-gui/using-cpp-exceptions-in-touchgfx-application/m-p/267439
is C++ handle exception included in TouchGFX release ?
I did not manage with the code here below, testing a string for a float with std::stof. (TouchGFX 4.21.4)
JJame.1
Hi Louis,
I use GCC but I found a solution using sscanf from this post : https://community.st.com/t5/stm32-mcus-products/floating-point-support-in-sscanf/td-p/429726
2 REPLIES 2
LouisB
Hello @JJame.1 ,
Exceptions can be use in your project's code but are not handled by default, and the TouchGfx library is not compiled with exceptions.
Can you tell me which ToolChain you are using?
Regards,
Louis BOUDO
JJame.1
Hi Louis,
