2024-05-09 3:31 AM
Is it possible to change TouchGFX framebuffer pixel format(LTDC) at runtime? If yes, how?
2024-05-10 3:53 AM
Hello @heyo ,
It's not possible to change the pixel format at runtime. Could I ask you why you want to change the pixel format at runtime?
2024-05-10 5:10 AM - edited 2024-05-10 5:11 AM
My whole system works on RGB565 , but in main screen view I've got radient image which I want to change to RGB888 for better rendering. In RGB565 pixel format the lines are visible and the image is not quality.
I set RGB565 format for better experience because with RGB888 its lagging
2024-05-16 2:19 AM
Hello @heyo ,
I understand, have you tried to change the Dither Algorithm? Maybe it can help you to make your image look better.
