Touchgfx designer simulator no show windows
YCF.1
Use TouchGFX designer to run simulator ,but not show simulator result windows.
view Log context below, What caused do this?
Thanks.
4 REPLIES 4
MM..1
Chief III
I mean your simulator run and crash in start. Locate exe in folder and try run it.
YCF.1
Hi~
I Use TouchGFX designer to run simulator, no pop up any windows and no find file simulator.exe
Maybe you need first learn use your PC and open file explorer in project goto build/bin folder
YCF.1
Hi!
I try to reinstall "TouchGFX 4.18.0 Designer" still can't generated simulator.exe on ..\TouchGFX\bin.
This question still not clean why to happen.
