Touchgfx Designer 4.19.1 used too many PC RAM
achan.12
I have already use designer 4.18 and 4.19.1 for same project.
The 4.18 used ram about 1000 MB . When I change to 4.19.1 , ram used to 4600 MB. sometime used to 7800 MB. Make my PC slow down.
How to solve this problem?
Thanks.
4.19.1 picture
0693W00000Np94QQAR.png0693W00000Np954QAB.png0693W00000Np959QAB.png0693W00000Np94zQAB.png4.18 for same project
11 REPLIES 11
Yoann KLEIN
Hello @achan.12​ ,
Can you please share or describe your project ?
It will be quite hard to help you without more information.
Thanks,
/Yoann
Yoann KLEIN
Ask is about PC RAM not target then maybe better is change subject to too many PC RAM
Seems newer isnt better alltime
OK . I'll cahnge to subject.
Thanks.​
I give some picture for Designer 4.19.1.
Pic 1: The Designer 4.19.1 standby and used PC Ram on PC.0693W00000Np94QQAR.png0693W00000Np959QAB.png0693W00000Np954QAB.png0693W00000Np94zQAB.png
The old designer 4.18.0 for same project.
Yoann KLEIN
Did you try to run your project with another computer ?
Can you also please share your project so we can test it ?
Thanks,
/Yoann
Yoann KLEIN
I tried this project ​with another computer and get the same result.
 Project link: https://drive.google.com/file/d/1-JrBctIpUDJ8cb6QvBQfkUMbqi1ai7SV/view?usp=sharing
Thanks,
The file "CircularArray.hpp" is missing, then I can not run the simulator.
Can you make sure to include everything in the project and then share it again to me ?
/Yoann
Yoann KLEIN
Why you used the simulator?
The problem is only on Designer.
When you used designer and switch the screen then monitor the PC ram.
You will find the problem again.
