toggle button positon set at inialt level when we change the screen.
Ranjeet Singh
0693W00000Y83I5QAJ.pngif i will change this codition to "off" state during program excuation it will change to "off" .but when i change screen to another screen the position is came to starting point "on".
Yoann KLEIN
Hello @Ranjeet Singh​,
You will have to save the state of your toggle buttons (with a boolean variable for example) in the Model, and then read this value every time you switch back on your Screen (in the setupScreen() method inside ScreenView.cpp).
To do that, you can take a look at this article of our documentation, and also this one for a simple tutorial.
Moreover, you can try out the project I shared in this post.
It can help you understand how to save value in the model from the View and propagate values the other way.
/Yoann
Yoann KLEIN
5 REPLIES 5
Yoann KLEIN
/Yoann
Yoann KLEIN
ok thank you sir,i will try
Hi @Yoann KLEIN​ ,
I started to use TouchGFX few days ago and it took me a while to understand that there is only 1 Model for the whole GFX (I come from Qt world so had to readjust to GFX's use of Model concept). I think it would help a lot if this was emphasized in docementation a bit more eg:
Or as it is done in this document:
www(dot)e4ds(dot)com/prom/files/Quest_5_Material.pdf
Ferro
Hello @ferro​,
Thanks for the input, I will report this element to my colleagues.
/Yoann
Yoann KLEIN
sir,can we transfer touch gfx screen data to our monitor through any protocol..?
