STM32H7B3I-EVAL + TouchGFX + FDCAN + "SD card"
HJang.2
I tried fdcan, touchgfx with stm32h7b3i-eval. I want to operate the SD card additionally, but it doesn't work.
Here are the ioc settings:
SDMMC1 -> SD 4bits Wide bus
FATFS -> check SD Card
If you disable "use dma tempate", it works, but if you want to use it with rtos, you have to enable it, but it doesn't work in this part.
f_open() returns FR_NOT_READY...
Please take a look at my project and point out the problematic parts.
thank you.
1 REPLY 1
MUdai.1
Hey, My reply dosent answer your question but i have an issue myself. I am currently trying to work FDCAN+Touchgfx. Problem that i am running into is my can bus is just showing Bus Errors -(Other Errors). I can individually make fdcan work. But when combined with touchgfx. It dosent work. Any help will be appreciated.
for further discussion my email id is- murtazau12@hotmail.com.
