stm32h7b3i-dk : How to add arm_math / dsp to touchgfx application
AmrithHN
I was able to successfully use arm_math.h in stm32cubeIDE and I did the same for the touchgfx application generated cubeIDE project.
But when I tried compiling the same with touchgfx , it was showing an error  "arm_math.h" not found however , building the stm32cubeIDE project generated by touchgfx builds fine.
I am totally lost how to integrate DSP library to touchgfx so it can flash along with UI
3 REPLIES 3
SofLit
Maybe this article can help you.
PS:
Thank you for responding.
I had followed the same while setting up stm32cubeide. problem is that touchgfx doesn't see those and uses a different make files to build project.
Basically touchgfx needs to see the config that stm32cubeide compiler settings/ include paths etc. I am so. confused why touchgfx uses a different makefile for building project.
Check out this example:
https://github.com/HanzoutiMehdi/fft_touchgfx_stm32h7
A link to the video
PS:
