2020-03-17 6:30 AM
Someone knows what this means as it appears after compilation after joining Touch GFX:
Unresolved inclusion
2020-04-08 3:49 AM
Will this work?
in main.c uint8_t var;
in model.hpp bool var;
2020-04-09 3:52 AM
Why the variable uint8_t var in main.c gives an error with var = true; ?
2020-08-01 11:00 AM
2020-08-03 12:40 AM
The enclosed file has empty functions so I guess you are not using the Touch feature of your screen (if any).
I don't know why you have missing address errors. You don't provide any info that could make it possible to try figuring out something.
/Alexandre
