2020-11-27 04:44 AM
Open STM32H7BWorkshop2020 STM32H7B3I-DK.ioc first do not migrate, and generate code. Then migrate and generate code. Then check content of static void MX_LTDC_Init(void)
2020-12-30 05:40 AM
Hello @Community member ,
Normally this issue has been fixed with the 6.1.0 CubeMX version, can you please check with it ?
Thanks, Khouloud
2021-01-07 12:01 AM
Hi, thanks for reply.
I am currently using 6.1.1 but i did not check if fixed. Just modified the produced code removing manually the second layer.
